Results 1 to 5 of 5
Thread: VP V6 Flywheel... is this bad?
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Default VP V6 Flywheel... is this bad?
    I have just removed a flywheel from a VP V6, and when removing the clutch I broke one of the dowels off the flywheel... (is that what there called? The 3 metal bits sticking out that the clutch holds onto) I also noticed that one of the dowels is missing completely, so now there is only one left on the flywheel. My question is, will this be a problem only having one left on there?
    Cheers guys.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    should get them replaced i think theyre mainly for centering the clutch but theyd probably have some holding effect aswell
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VP Executive Sedan
    Mar 2009
    They should be removable as most clutch places will remove them in order to "face" the wheel.
    Maybe approach a clutch specialist to find replacements?
    dans_vz's Avatar
    Aug 2006
    Albury/Wodonga
    Quote Originally Posted by wagonist View Post
    Oh ok then, well I have to get the flywheel machined anyway.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    they are just a standard solid dowel would be pretty easy to find some from a bolts place. they work on a slight interference fit
  1. Flywheel
    By ecotec38 in forum Yella Terra
    Last Post: 28-08-2008, 03:15 PM
  2. WTB vp v6 flywheel
    By Matt_vp in forum Swap / Wanted to Buy / Trade
    Last Post: 15-08-2008, 03:09 AM
  3. flywheel
    By surfindude in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2006, 03:15 PM
  4. vn s2 flywheel
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 07:52 PM
  5. Vk Flywheel
    By LeonH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-03-2004, 08:22 PM
