Hi
Gota vn s1 auto
-In the mornigs it takes a few seconds to engage D or R and wehter cold or not it always gos into gear with a cluck (whole car moves).
-When driving sometimes it changes with a bit of a jerk, sometimes from 2-3 it kinda grinds a bit and sometimes its really smooth.
-When I plant it it changes around 4500-5000rpm and is ALWAYS really smooth.
Is this normal and also would fluid and filter change help.
also i know one of the transmision mounts needs replacing is this related and is it easy to do.
soz for the long post but jus curious thanks.
I may have broken the law, but that doesn't make it wrong!
too me sounds like the kick down cable needs to be adjusted and the transmission needs a severse
could have wrong trans fluid in there too. if you put the wrong type in there they act like a b*tch sometimes. same as not having enough
go a full service my guess is that it probably hasn't had a service since new
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
I also own a VN s1 and i also have the same problem when my car is cold it takes awhile for it to click into D or R. But when its warm its perfect and no clunking.
It is due for a oil change BAD so that might be the cause.
Change your oil and see how it goes from there
Yeah a service is the best thing you can do.
But if you are low on cash then try and do as much things your self before you take it in i say.
cheers guys, i might try the fluid and filter change asap and go from there. hopefully it improves.
