Results 1 to 4 of 4
Thread: clutch or gearbox!!!!!!????????
    91 lexcen vn S2
    Nov 2005
    heathmont
    Default clutch or gearbox!!!!!!????????
    hey guys...
    i've had this issue for a few weeks now and it seems to be getting worse and worse.....
    ill be driving, and then when i go to put my foot down the car jsut revs...like its disengaging from the clutch....so i pop the clutch and try again and most of the time it works....it started off only in fifth gear...then forth..now its in third...
    i was thinking that i just had a burnt out clutch.....but then i got confused because i thought...if it was the clutch then shouldnt it of started with all the gears seeing as the clutch doesnt really change in density for each different gear.....but i know nothing about transmissions or clutches or that stuff...
    the issue isnt in first or second yet but im sure it will get there.....like i said it only happens when i put my foot down to accelerate and the car starts to move but then rrrrvvvvvvvvmmmmmmmm......
    any tips on this issue would be great i dont know whether to buy a clutch or a new gearbox....
    thanks
    MAtt
    YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
    Morton's Avatar
    Morton is online now For external use only
    Fairstar the Funship
    May 2006
    You need a new clutch - it's just slipping. It's only happening in higher gears first, because that's when the most torque load is being applied to the clutch. In high gear at low-mid rpm the clutch won't be able to take it.
    The 1972 HQ Kingswood
    Vp series 2
    Jun 2008
    What he said. you may even be able to smell a burnt smell after if has been slipping a bit.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by Morton View Post
    not always the case, he may just need a new friction disc, the pressure plate may be fine...
    aZK.
  1. Replacing gearbox and clutch VR
    By bloodylegend in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2012, 06:53 PM
  2. VE SS Clutch/Gearbox
    By xss001 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-05-2011, 10:26 AM
  3. vs what gearbox/clutch?
    By Bode88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 02:22 PM
  4. VS Ute gearbox/clutch?
    By overgrown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2008, 09:44 PM
  5. gearbox? clutch?
    By bassmansimon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2007, 08:16 PM
