Results 1 to 3 of 3
Thread: headlights flicker sometimes
    VN Calais 1990 V6 3.8L
    Jul 2008
    around revesby
    Default headlights flicker sometimes
    okay so my s1 vn calais...
    the headlights just used to go out for about half a second or so if i drove off a gutter abit rough, or went over a big bump,
    but now im gettin worried, because they flick of for about half a second or so when at idle, and yeah they still go out when i take it bush bashing
    anyone got any ideas?
    (apart from me treating the vn with more respect)
    well i have been looking after it lately anyway
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    had a headlight issue once, the headlights would occasionally fail to work, kept flicking the switch back and forth and going high beam/low beam/high beam etc (in backstreets) and they'd come on after a bit.
    holden said switch block, quoted something ridiculous, like 300.
    got a switch block from a wrecker, made no difference.
    took the fuse out from under the bonnet, cleaned its terminals. worked fine after that.
    Jul 2008
    around revesby
    BINGO!
    found the prob
    thanks pow3rslave, i just popped the bonnet, checked the fuse,
    to find it with absolutly filthy terminals, and the bloody things melted,
    like the fuse is slowly blowing over time :S
    i DO have higher wattage globes fitted, so that would explain that,
    problem fixed, put old bulbs back in for low beams, and new fuse, cleaned, its running fine now
  1. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  2. VY Headlights..
    By HoldrodeoLT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2008, 08:59 AM
  3. Hazard Lights Flicker
    By Toddy_59 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2008, 06:26 PM
  4. headlight flicker
    By phantom_canary in forum General
    Last Post: 28-05-2006, 11:42 PM
  5. 3 Window Cluster Flicker Problem
    By zacz in forum Electrical Wiring / Questions
    Last Post: 19-10-2005, 12:54 AM
