Does the wagon have a coil or leaf sprung rear end?
I want to know if I can fit the wagon stuff into the back end of my sedan to stop it's butt dropping on the ground when the car trailer & excel are hitched up.
Live axle with coil springs and panhard rod. AFAIK it's the same as a live axle sedan however the tailshaft is different.
Reaper
I was thinking more just the rear shocks & springs.
Surely the wagon stuff got to be heavier duty than the sedan
shocks are different lengths between sedan and wagon(due to mounting points on diff and body), and from memory cant be interchanged.
springs will swap over without a problem
uppers definately different, and im sure the mount on the diff is different aswell.
As its the springs that determine how much the car sags, sounds like a goer.
Thanks for the help.![]()
wagon springs would be a bit harder to.
ide be fitting some air shocks
Unfortunately, budget constraints rule out anything like air shocks.
I just had a thought. Is there any reason why the rear springs & shocks out of my VN sedan wouldn't fit? It certainly was nowhere near as soft.
Any Ute or Wagon springs would be fine hence being heavy duty.
