Results 1 to 9 of 9
Thread: vn cruise
    vt executive station wagon
    Jan 2008
    Default vn cruise
    hi i brought a vn that i am slowly doing up at a daily so that i can take my other car off the road for a bit to fix it up
    now the cruise doesnt work.... and i was just wondering what the common faults are so that i can see if i can get it going...
    what would cause it to stop working in the first place.... as far as i know all the fuses are fine.... but will have another look
    thanks for any advice in advance
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by sv0478 View Post
    Most common problem is incorrect adjustment on the brake switch. Drop the panel under the steering wheel, and you will see the two switches on the brake pedal. determine which is for the cruise and make sure it is adjusted properly
    Power is measured in DECIBEL
    Jan 2008
    hey thanks for that...
    i found the 2 switches and worked out which is which
    now i have another question
    how many wires are suppose to be going to the switch?
    the brake has 4 going to it and the cruise has only 2
    is this correct or is the cruise suppose to have 4 going to it also?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Sounds right, maybe the cruise passes through both switches? (hence 4 wires on the brake light switch). The brown wire is for the cruise. no just make sure the switch is making contact with the pedal when it is at rest.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    This is how to set the brake switch
    and 3 Dangerous non ABS VN's
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    For a simplified vn/p cruise control circuit look here http://forums.justcommodores.com.au/...ol-circuit.jpg
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Jan 2008
    thanks for all the info guys
    now to go and figures all this out and see whats going on
    slip'n_sideways is offline super sideways
    VR Wagon
    May 2009
    Default tappets
    does anyone no how much tappets are??? my car is making a ticking noise and im guessing its it anyone know about the prices on them. . the cheapes??
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by slip'n_sideways View Post
    You wont get much luck in this thread mate
