hey guys just wondering if the ignition setup changed from vn-vr or vs 304?
Current ride: Vn Berlina 304
Previous rides:
1988 Vl Berlina
1990 Vn Bt1 5L
1986 Vl Sl
No, the ecu changed but everything else stayed the same, actually someone mentioned the other day that the plug on the dizzy changed
is there a write up on here on how to remove and replace the coil pack??? as i want to replace myn... how much does a new one cost roughly nowadays?
Previous rides:
1988 Vl Berlina
1990 Vn Bt1 5L
1986 Vl Sl
There is no coil pack. There's a coil and an ignition module both are 5 minute plug in jobs. Coils are cheap (60 bucks?) Ignition modules are 600+
yeah the only difference between the models are vn-vp1 has small plug on dizzy and vp2-vs has large plug on dizzy... also have differnt part numbers but u can swap these plugs over to suit eachother.
yeah replaced ignition module $220 plus mine in exchange(530 without exchange) and $50 for coil... yeah didnt mean coil pack just coil my bad... coil took bit longer than 5 mins lol so hard to get at
Previous rides:
1988 Vl Berlina
1990 Vn Bt1 5L
1986 Vl Sl
