Results 1 to 7 of 7
Thread: Painting
    vn90
    Dec 2008
    Default Painting
    ok guys
    befor i atemped to resrpay my car i need to no few things
    do u guys think its better to sand car befor spraying primer
    if so want grip should i use
    n were shud i get it from
    Smallies's Avatar
    Smallies is offline I hate carnies.
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    lol, It really depends on the quality of the job you want. For any paint job - I think going over the whole car with sandpaper would be a wise choice. Nothing too rough, a fairly fine one - something that wont dig in. Youll need a fair bit of it, and a sanding block, and a strong arm lol. Just go suss out a hardware store.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    defiantly sand it to at least ruff the clear coat ive found that the paint sticks better all round also wipe it down after your finished with thinners that helps remove any oil deposits in the paint before undercoat
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VR Equipe
    Jun 2005
    Quote Originally Posted by MAC-VN View Post
    ok guys
    if you dont sand the paint down before primer, the paint and primer will peel off, and you wont be able to feather the edges of the primer either
    it may sound easy to spray a car yourself, but there are a lot of things to know to do a good job, and most of these come with experience
    vp berlina
    Apr 2009
    definietly sand it bak.with a block with 800 wet paper,then after primer,spary a light coat of black as a guide coat and block it back with a longblock wiith 400 grit wet then another light coat of black then block back with 800 wet.should be sweet
    VN S1
    Jan 2008
    Im in the middle of sanding down my vn previous owner 2 pak'd it but never clear coated so a small knock and it flakes off, ive found 100 grit to remove the 2 pak, then 220 grit to rough it up, then hit it with finer stuff between coats.
    VN S2 V6 Berlina
    Apr 2007
    Hey Mac,
    Good to see that you're having a go at something that won't risk your life it if doesn't turn out right. Just remember to NOT paint the windows. Good luck.
  1. Painting VT
    By batty_123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2008, 06:32 PM
  2. painting
    By Vy_rizza in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-07-2008, 11:53 AM
  3. painting my vp, what do i need?
    By benjiaka in forum General
    Last Post: 08-11-2007, 10:48 AM
  4. painting...
    By rattattack1313 in forum The Pub
    Last Post: 06-07-2005, 06:33 AM
  5. Painting
    By DaveP in forum General
    Last Post: 02-02-2004, 07:13 PM
