ok guys just got some narva 100w foglights
n i need help installing them on in my car
vns1
i have no clue how to do it
this is how im thinking atm
with the 1 long wire thing i got
that i cut that in half for the for the 2 wires coming from frist light then cut more off connect to the frist light then them 2 wires coming from both lights run to the relay then one wire runs from reply to battery
n then another pieace of wire runs to the switch
is that all it is
i only got 1 pieace of wire with it so witch side do i connect to the batty
i dont think theres gonna be enuf wire so can i use speaker wire
Yeah its just one long skinny black wire?
those wiring kits the lights come with are CRAP! non insulated crimp terminals and you can only use that black wire for the switch, its not heavy duty enough to use for the lights, and no you cant use speaker wire!
You are far better off going and purchasing a proper wiring kit from supercheap or somewhere, thats my advice.
Power is measured in DECIBEL
how much are wireing kits wat they called?
ill try use this one for now so its only 1 wire that goes to the battery
n 1 wire to the switch n thats it
what side of the battery
and what other wire can i use
Theyre just called a driving light wiring kit, about $25 - much better than mucking around with what comes with your lights, because you still need a fuseholder for the main power wire to the battery, insulated terminals, and higher gauge wire for the lights. By the time you buy that stuff you would have been better off buying the kit.
i got like crimps n that with it i just needa make sure wat im doing is right
what other wire can i use for now
i thought speaker wire wld be ok till i got wireing kit
its got likle termals thingys with it
so i wont be able to use this wireing kit at all
No speaker wire will not carry the current needed by the lights - not recommended.
Yes but those terminals are not insulated, you would have to wrap all joins with electrical tape. I wouldnt try using that kit, it doesnt come with everthing you need so best to buy a proper kit that has a fuseholder and correct wires.
Heres a quick diagram
ok im going to wait n gt a kit will the it have everthing i need
with ur diagram
my lights have to lil holes in each one were i take it u push the wire into
so theres to wires coming from each light then they join with other to wires from other light then down to the 2 slots on the relay
then one wire to the switch n one wire to the battery + side
n thats it
ok what to u mean crimp on the lights lol sorry im not smart ah
thanks for all ur help were wld be best place to go for good kit supercheap
crimp those little blue terminals they come with. You'll see when you buy the kit
Last time i was at supercheap they had them. Or try ebay
SPOT LIGHT WIRING KIT COMPLETE, SWITCH, RELAY & WIRING - eBay 4x4 Accessories, Exterior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 20-May-09 21:00:00 AEST)
IPF STYLE WIRING KIT FOR SPOT FOG FLOOD DRIVING LIGHTS - eBay Other Lights, Indicators, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-May-09 13:07:56 AEST)
ill just go down supercheap n get one
thanks for ur help now i needa find place to put them ahaha
well as u no the vns front bumper hae like metal railing suporting behind the bumper were the gap is im wounder is i can drill 2 hols to bolt them up
so u no if a drill will go thou ahah
i still cant get over that i paid 150bucks for them ah
ok i got wirei9ng kit like the one u showed me on ebay
how do i connect the lights to wires
i got the squat lights with 2 lil holes in back of them were the old wireing kit goes
please help
n with the digra the black wires that go no were were do i put them
ok i took from of the light off to see were i connecnt the wires n there only with metal slip thing for the white wire to go on
so weres the black one go
there wheres the black wire go thou
were do the red outlined ones go the i posted
n see the whiteline to the swicth can i cut that n put it on my owen switch thanks for helping i owen u one bigtime
now that i looked at teh globes theres a lil wire coming off them with a tab on it so wtf is that for
