my dash cluster/reverse light fuse keeps blowing i put new ones in and they last about 10-15mins.
it has a level 3 cluster in it but the digital part doesnt work and the fuse is the same for the reverse lights, my mate said to try taking out my reverse bulbs but it made no difference.
thanks
jay
Sounds like a pick apart job, if you aren't to keen on homestyle auto-electrical work, drop it in to an auto-electrician so he can back-probe it.
Check out my VP right 'ere!
anyone????
Is it a Calais or have you fitted a L3 cluster without the 4th plug for the trip computer.
As for the fuse blowing - is it when you selsect reverse - if so have a look at the reverse switch on the gear stick - you will have an exposed wire some where
and 3 Dangerous non ABS VN's
not calais, it was in there when i bought it. will do some looking around with the switch though, thanks
