Results 1 to 14 of 14
Thread: quick help
    vn90
    Dec 2008
    Default quick help
    ok guys i need to get a wire form my motorbay to the inside of my car whats the best way to do it
    vns1
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by MAC-VN View Post
    vns1
    Through a rubber grommit in the firewall. Here is a few pictures to show you where
    Installing amp in a VS calais
    How run power cable to VS battery
    Power is measured in DECIBEL
    vn90
    Dec 2008
    AHAHA THANKS wish i had of known that early i just put push the otherrubber mouth thing were the driving lights n things go n put it throw there ah
    ill probly go back one day soon i really tidy it all up n stuff kinda half assed it for now got a tatto healing n its hard to work on car without hitting it ahah
    VB SL/E
    Dec 2008
    Just make sure it does not cut thru the insulation where the wire passes thru the body as you may have a car fire if not fused correctly.
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    ever since i removed this gromet to run leads through, i can hear my coolant being cycled through, from inside the cabin..Normal??
    WhyallaVp is offline Vp Berlina
    VS Clubsport
    Nov 2007
    Whyalla, SA
    Sure its not air in your heater lines? It should sound like a squishy sucking noise if it is. Wait for a cold start, open your radiator cap, turn on the heater and watch the level drop. Then top it up and it should go away.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    motorbay lmao.
    yeah holedncommodorevp , jst do what WhyallaVp said, u heater core probs running a bit low, had mine do this last coolant change, didnt have the heater tap open soo it fully drained, but couldnt top up itself.
    It does give a nice slushy noise aye
    ________________________________________
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    yeah it's sounds like a slushy noise...it never used to happen until i ripped out that gromet...So what are you saying, take the cap off the radiator, and just turn the heater on../?
    92 VP Calais 3.8
    May 2006
    Gold Coast
    yeah turn the heat up, it will open the valve to the heater box, then ur fluid level in the rad will drop as the core fills up.
    Mite not drop that much only needs a lil bit of air in the system to make it slush.
    Mite have hit sumfink when ur were under there, mite have a slight air leak on the heater hose join at the core, doubt it tho.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    92 VP Calais 3.8
    May 2006
    Gold Coast
    trust me its alot harder to get back in, i tried to get mine back into place with sum 0guage cable thru it, no chance, just silicon back into place sorta
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    I didnt even bother trying to get it back in, i've just left the hole there.
    92 VP Calais 3.8
    May 2006
    Gold Coast
    jst make sure that the cable aint rubbing on the firewall coz if it cuts thru the insulation, its goin to short out nicely.
    thats why i put mine back on hte silicond it there, soo no chance of my 0gauge shorting out n puttin 200amps down
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    Yeah ive been wondering about the long term possibilites.. Something was actually sparking the other day, around the shroud..I dont know what it is, then the interior light blew twice, and i opened the boot and discovered the brake light from the parcel shelf and falled down and burnt 3 holes in the carpet, and then melted itself to the boot hinge...!!!
  1. Quick electrical problem - requires quick answer
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2008, 08:29 PM
  2. quick help...
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 01:11 PM
  3. Quick help
    By Mr540 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2006, 09:27 PM
  4. quick Q..
    By -davo- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2006, 06:20 PM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
