Results 1 to 5 of 5
Thread: cant select 'p' park
    Dec 2005
    Default cant select 'p' park
    put new box in, and what a surprise ... it will not select PARK, its like the lever is jammed.. selects every other gear fine, we changed and adjusted the bar on the gearbox(selector bar on the box itself, not the T!) and still no luck . could this gearbox be stuffed?
    Aug 2004
    mine does the same, its something to do with something called the pewaul adustment or pin or some such shit id LOVE to know how youv fixed it though!
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    You sure the plate that has "P, R, D" etc etc on it, just need to be adjusted?
    Or will the car actually NOT go into park? If the car goes into park, then pull the shifter surround up and take the plastic plate and move it up a bit until the white square is inline with whatever gear it's in or reverse etc.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    Vp series 2
    Jun 2008
    put the car up on stands, hand brake on and select 1 on the shifter and get under the car.
    now undo the adjuster bolt at the REAR of the shaft.
    Push the shaft further forward and feel for a click.
    if you feel one then do up the djuster bolt and all done.
    if not click then move the shaft and and count how many clicks there are.
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by cracker View Post
    Mine also does this from time to time, when i pull up it wont go into park. If i turn the car off, then it goes in to park fine.......Wierd...... But i'll never getit fixed, because "one" day, there will be a manual in there
  1. Paddle shift / active select
    By Slick6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-04-2012, 07:25 AM
  2. Only able to select High Fan in WK Statesman
    By STATSMAN in forum General
    Last Post: 30-11-2009, 07:27 AM
  3. How's the Active Select?
    By PhantomSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2009, 07:17 AM
  4. Active Select acting up (i think)
    By brownie82 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2007, 05:03 PM
  5. VZ Adventra Active Select
    By AWD_VZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-11-2005, 09:41 PM
