Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Brake upgrade options
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Default Brake upgrade options
    Now I don't think there will be many people who can answer this question but i'm going to throw it out there any way.
    I'm trying to work out which way to go with regards to brakes from the following two options;
    Option 1: Group A/GTS setup. Twin piston calipers on 327mmx28mm rotors
    Option 2: VT HSV upgrade. Twin piston C5 calipers on 330mmx32mm rotors with VT booster and master.
    Now the VT setup is going to cost alot more then the Group A is so my question is has anyone driven with both setups? Is the added expense of the VT setup going to give a substantial differnece in the braking?
    I had the standard VT setup on my VR with the stock booster and 1" master and was fairly happy with it but still had some pedal travel, hance the booster upgrade.
    MasterOfReality's Avatar
    MasterOfReality is online now Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Same question that I asked ages ago but didn't really get a response.
    Everyone I asked had different opinions, from engineers, mechanics and brake workshops.
    I was going to go for the Group A setup, as no engineer cert is required, so less hassle, but I couldn't find a front and rear set for a decent price.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    I couldn't speak to the stopping power of either, but i always heard the vt setup needed engineering because of the adaptor plate, whereas because the group a were an optional (albeit top end) brake for the vn, they were ok.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by pow3rslave View Post
    Who honestly gets anything engineered? Did you get your engine mods EPA tested and signed off? lol
    Not worried about the legalities of it but after which kit is better.
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    Quote Originally Posted by AirStrike View Post
    my engine doesn't have mods, it has... eccentricities
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Use the VE spec upgrade kit. Comes with 330mm rotors, VE calipers, pads, braided lines, fluid and all the mounting hardware including hubs to suit the VN. No need to upgrade the booster or the master as the pistons in the calipers have similar displacement to the stock single piston items.
    Visit my Facebook page
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Hmmm interesting. Any more info on the kit?
    VP Executive R-spec
    Jan 2005
    I don't know of anyone that's had both but I know lots of people with the VT brakes and don't think they are all they could be. I'd be going with group A infact I'd just be happy with a brake pedal that moved right now
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    if ya want the Vt booster i have the race brakes one that i am not gunna use, its the vt booster with the adapters for your brake lines an the adapter to fit the brake pedal or something like that, anyway vt booster to fit vn vp, all it needs is a mastre cylnder...
    May 2006
    Perth, Western Aust
    Jun 2005
    yeah i was going to suggest the VE upgrade kit. with a vt master cylinder, you will need line adapters. vn_luke got them somewhere. you will also need to modify a bracket for a vt booster, or just use a vs booster that bolts straight up
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by stocky View Post
    Got the modded bracket and a VT booster here, just need to mod the pushrod length and get the double to single flare adaptors (got a price from Hoppers Stoppers last time around $3-4 each).
    Jun 2005
    i think you just need to drill a hole in the pushrod to modify it
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Two things, weld up the old hole and move it and also shorten the pushrod length.
    http://users.bigpond.net.au/jimbo123/VN/
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There is this Press Releases
    322mm rotors, sorry, not 330mm.
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Interesting. If it will work with the standard booster and master all the better. Got a price at all mate?
  17. #17
    VP ute
    Mar 2006
    I had a good conversation with Matt at Race Brakes Sydney on this topic and he said he preferred the Group A set up. Much simpler and works equally as well offering the best bang for your buck. It was also matched to the existing brake system on the VN-VP. This was in reference to converting brakes on a old school Commodore.
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I have sold this exact set up to another member on here and he didn't have to replace the master or the booster. The only drama is that the calipers are marked left and right, but you fit them the other way around so the bleeders are up the top. I will pm a price to you.
  19. #19
    vp 5L
    Jul 2008
    goldcoast
    how much for the ve kit without the hub adapters because i already have them for my vt brakes, al so does the vt booster make the brakes work better
  20. #20
    May 2006
    Perth, Western Aust
    Yep that would be me - VERRRY happy customer - though i drive my car like once a weekend maybe if im lucky so i dont notice any extra pedal travel others who drive theres all the time might do - but i can say i can lock the brakes up real easy and the pedal doesnt hit the floor..... also im using the stock booster and master for my vp..
  21. #21
    89 VN
    Feb 2009
    How much is this mate sounds nice and easy?
  22. #22
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i have the VS GTS twin pot 330mm brake setup on my VS and it was easy as, just a note: get new brake hoses (braided or rubber, it doesnt matter) and get them 150mm longer than the standard VN-VS hoses. mine dont sit in the bracket on the strut tower, just a little too short lock to lock.
    i recomment this setup, same bolt up, essentially no cert required as they are off the same car. also no need to change the master or booster.
  23. #23
    May 2006
    Perth, Western Aust
    think mine cost me $765 was easy as piSS to install, and i know nothin bout brakes - just make sure if ya get the Ve brakes they go on opposite to what they are stamped as the VE brakes are on the back of the calliper and the Vn/vp are at the front of the calliper also
  24. Default
    interesting, my car doesn't really stop (sometimes i wonder if it's just my car or if it's normal). would like to hear more about them, but...
    *298 diam fits std wheel sizes from 16"
    *322 diam fits most wheel sizes from 17"
    i run 15 inch stockies, no chance of them fitting?
    Quote Originally Posted by zai View Post
    I am not sutpid
  25. #25
    VP Executive R-spec
    Jan 2005
    My car before it broke was able to lock up the wheels from 100 without any real problem that's how a stock 5 litres brakes shoudl work. If not you have issues
  1. Stereo System upgrade options
    By Claymore in forum Car Audio
    Last Post: 13-01-2009, 01:09 AM
  2. Engine replace/upgrade options for VP
    By bad benny in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2008, 02:00 AM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. Brake upgrade options?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 06:03 PM
  5. brake bias options
    By jazz in forum Motorsport
    Last Post: 27-07-2005, 11:08 PM
