Results 1 to 5 of 5
Thread: harmonic balancer and crank angle sensor for vp s2 (same as s1?)
    VN Commodore (S2)
    May 2009
    Question harmonic balancer and crank angle sensor for vp s2 (same as s1?)
    hey i was just wondering if the harmonic balancer and the crank angle sensor are the same on the vp series 1 and the vp series 2. i have a vp sitting around that needs these peices and i have a mate wrecking a vp who has those peices but off a series one. if i was to grab the harmonic ballancer and the crank angle sensor from the vp series 1, cud i throw them on the vp series 2 engine?
    please any help would be appreciated. thanks
    -icePiK
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    yes providing you have the matching pair it will be fine that is to say it will fit and run just dont forget later down the track
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VN Commodore (S2)
    May 2009
    ey rob, ta for the help. your tellin me to remember that the harmonic/crankangle set is for a s1, so dont replace with the original? (s2) say if we did another harmonic ballancer, replace with a s1 harmonic because the sensor is s1?
    Jun 2008
    golden beach
    bingo they dont mix and mach must be a matching pair
    VN Exec V6S1 man
    Aug 2007
    Adelaide SA
    yes all interchangable VN through to Vr
  1. Crank angle sensor
    By batemada in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-11-2007, 05:38 PM
  2. Remove Harmonic Balancer to change Crank Angle Sensor?
    By aklahr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 09:18 PM
  3. Crank Angle Sensor
    By s0sage in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2007, 11:49 PM
  4. Locking crank for harmonic balancer removal?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2006, 01:22 PM
  5. Harmonic Balancer / Crank Shaft Pulley
    By knight97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2005, 07:38 PM
Tags for this Thread
