Hi all,
I have just bought a VP Calais, picked it up for $1500 with 220thou on the clock, needs the paint on bonnet fixed up and a few scratches hear and there. Good buy I think(used to own a VP Berlina).
I have a couple of issues that I wanted some help on:
The car runs a bit rich on fuel and also doesn't really move off the temp gauge unless I leave it idiling for ages, could this be coolant temp sensor?
I'm going to replace that, air filter was also really dirty so I replaced that already.
The central locking has an issue, the rear left door doesn't lock with the central locking at all, why could this be? And the front left door is really hard to lock so it is making the central locking try to lock but wont and they all pop back up again.
The auto fluid smells cooked and the auto seems like its making the car really sluggish when the car is cold like doesn't want to shift into 2nd gear for ages, and when doing 110 on the freeway and going up a hill it wont kick back I just hear a vibration like its trying to get it to kick back but cant do it. I think it might also be a bit low on fluid, how am I meant to check it properly?
(Going to put a manual gearbox in at some point)
Thanks everyone.
anyone?....
no offense but theres no way i would pay 1500 for a vp Calais with those issues if the fluid smells that bad the hole box will need a service that is if there isn't any major damage already as for the left hand rear door i have the same issue and it un locks but wont lock with the rest of the locks so i dont know the answer to that one
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
in that case cool good luck![]()
$1500 isn't bad, i sold my vn which was an exec with 330xxx kms for $1250
i'd try changing the coolant temp sensor first. see how that goes.
well as ive said in the past 750 is my limit for any vn vp v6 and i own 3 of them
Anyway - back to your original questions.
Regarding the door locks - try this thread
central locking only does 3 doors
People ask about door locks all the time. Your front door seems to be trying to lock/unlock - so that might just need freeing up. Your back door might be a slightly bigger issue if its not even trying. Door trims need to come off though anyways.
You might needa chuck that manual in pretty soon too by the sounds of it haha. ah well, congrats on the purchase bud - i just bought a vn calais.![]()
lol I have the same problem with my right read door.
Try checking your computer for faults.
Checking your Computer for Faults (VN - VP)
wouldnt be your coolant temp sensor i dont think, probably your thermostat.
yep, same prob ive had for a while, not a huge drama, and pretty easy to fix yourself. Since the car is colder it will use a little more fuel.
Also with your trans, it sounds as though your lock up convertor has let go, especially with the fluid being burnt and struggling up a hill.
