Results 1 to 16 of 16
Thread: Key Refuses To Unlock Drivers Door
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    Default Key Refuses To Unlock Drivers Door
    Okay, so I finished work and went out to the car to head on home and found that my key refuses to turn in my drivers side door lock.
    After searching the multitudes of posts on the forums, have found none that quite match my issue.
    The door is not deadlocked, the lock is vertical not horizontal, I can turn the key in the passenger side door and get into the car, the problem is that the key will not budge in the drivers side lock. Its not the key, as the spare key does the same thing. Its slightly frustrating... any ideas?
    Morton's Avatar
    Morton is online now For external use only
    Fairstar the Funship
    May 2006
    can you unlock the driver side door from the inside?
    The 1972 HQ Kingswood
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by Verillius View Post
    I think it's an elaborate practical joke your work mates have played on you. The old "change his door lock barrels while he isn't looking" trick. They must be amateurs though, you're supposed to do all the doors, then they try to climb in through the boot and you lock them in and go to the pub.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    Quote Originally Posted by Morton View Post
    I certainly can, that is what leads me to believe its not a deadbolt issue
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    okay, so found a post through google that suggested that maybe the lock was just jammed through grime buildup, grabbed some wd40 and sprayed inside the lock barrel and sure enough, with a little bit of pressure, shes come good.
    Morton's Avatar
    May 2006
    Awesome Glad you fixed it with something so simple!!
    1989 VN Executive Commodore
    Dec 2008
    Sydney, NSW
    Glad you broached this subject... I have been having the same issue with my passenger side door for yonks. Will give the WD40 a go too! Cheers
    VP Vacationer Wagon
    Apr 2006
    Bundy QLD
    just push the straw in about 5mm at a time, give a quick spray, then repeat until its all the way into the barrel, then give it about five minutes to soak in to the parts.
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by rosiebuttons View Post
    You really shouldn't use a oil based product in locks as over time the dust sticks to it a makes it more sticky.
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    Dec 2008
    Sydney, NSW
    Quote Originally Posted by bj42turbo View Post
    Dazz
    Thanks Dazz... I had already tried it last night, but it hasn't solved the problem LOL I have had a new key cut and that hasn't helped it either :S
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    Dazz
    ^^^ Yep, graphite powder only.
    WD40 may work for a while, but in the long run will cause the lock to fail again quicker.
    1990 VN Executive
    Nov 2005
    Mate was the key cut to code, rather than been duplicated of a worn sample.
    Dazz
    Dynamic Locksmiths
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    id have to say some1 has been tryin to break in ur car by the sounds of it. wat u can do it get ur lock checked out by locksmith and they should tell u wat it may be.
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    wez
    wez is offline
    VN S1
    Dec 2008
    I've had all kinds of trouble with VN locks, so good to read all the above.
    I'm just wondering how to get graphite powder into a lock. I'm surprised enough that dust can get in there.
  15. #15
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    get a soft pencil , sharpen it and draw a picture on the inside till its blunt
  16. #16
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by wez View Post
    You can buy them in puffer packs with a thin nosle. But bear in mind graphite is not a miricle cure for worn locks or keys.
    Dazz
    Dynamic Locksmiths
  1. Th Door won't unlock
    By Taddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-03-2010, 06:49 AM
  2. Passenger Door Deadlocked - Won't unlock!
    By Garrett10_4 in forum Electrical Wiring / Questions
    Last Post: 22-10-2008, 12:52 AM
  3. Passenger Side Door wont UNLOCK
    By hsvpunk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-05-2008, 10:36 AM
  4. Front door wont unlock please help asap
    By stumps5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 09:35 PM
  5. Other Doors Unlock When Drivers Door is Opened
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 09:55 AM
