Results 1 to 3 of 3
Thread: VN series 1 man. with blown engine
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Default VN series 1 man. with blown engine
    Hi all.
    I'm buying a cheapy VN Series one manual wagon in the next few days. here is my dillema.
    The car is complete except for an engine that has shat itself. As i understand, my only option is to fit another VN s1 manual engine because of the difference in crank.. correct? OR i could grab me a VR engine, but i will then need to buy a 8 bolt fly, and change radiator/ hoses etc? Now, am i correct in this current knowledge?
    is there anything else i should know?
    cheers for any help
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VP Executive R-spec
    Jan 2005
    Yep you will need the later engine and the flywheel. You can do a azzfox and get an auto motor and special flywheel adaptor thing that you can bolt your flex plate to
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    pity your in sa, i have a mint low km vn manual engine with a fair bit of grunt
  1. VT Engine - Blown?
    By endlesshysteria in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2009, 12:34 AM
  2. new engine after head gasket blown
    By nickg777 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 12:32 PM
  3. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
