Results 1 to 6 of 6
Thread: VN starting problem
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Talking VN starting problem
    hey guys.... im a newie and need lots of help and im hoping i have come to the right place
    i have a VN S1 and i have had a constant staring problem!
    the car will start straight away in the mornings no problem.. but if i drive it and then stop for 10 min..ill go to start it again and it will crank about 6 times then start and blow black smoke.. she neva blows black smoke on me.. then if i turn it off and start it again it will start straight away...
    i have changed ........... get ready for it!
    Crank angle sensor, coil pack, new leads, new plugs, i have done a carbon flush, fuel filter replaced, fuel regulator replaced, starter motor replaced, and had the battery checked and had the fuel pump replaced about 5 months ago.......
    i am begging for help please anything... its doing my head in...
    thanks
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yip sounds like the coolant sensor circuit in the ecu
    VP Executive R-spec
    Jan 2005
    Definitely leaky injectors in my opinion. If you leave it sitting long enough the fuel will dry up and it you start it again straight away it wont have leaked much. Somewhere in the middle then that's where you have problems
    VN Lukey's Avatar
    Holden VN S1
    May 2009
    thanks..
    i have replaced the computer aswell but still no improvment i forgot to put on in the list.. to many things to rememba..lol .... all that it did for some reason make the car really sluggish... i have got my old one in now.. is seems like it has more power for some reason...LOL.. dnt know how that could be...
    i might give the injectors a shot this weekend.... just some second hand ones from the wreckers...
    is there anything else it could be?..
    VN Lukey's Avatar
    Holden VN S1
    May 2009
    Hey Guys... Heads up.. i fixed it.. it was the leaking injectors... lol..
    after all that.. oh well now i wont have to worry so much about all the stuff i replaced later on down the track...
    an thanks so much greenfoam.. your a legend.. i went to so many mech's and the could not tell me anything... you saved me alot of money and headace...
    thanks again champ..
  1. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 04:58 PM
  2. Vt Starting problem
    By bubz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2007, 10:22 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. Starting problem
    By gooley in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2006, 09:47 PM
  5. Starting up Problem with VS
    By comitnycrym in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2005, 12:30 AM
