Results 1 to 12 of 12
Thread: in big trouble !!!!!!
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default in big trouble !!!!!!
    Should a VN boss kit fit a Vp? i got a Vn boss kit frm the wreckers which they said would fit, but it didnt. I grinded the tab down on the back of it, then it went on. Tightened it up, but the wheel wont turn, like its too tight. Took the wheel off, now i cant get the boss kit off. My car is parked on the foot path near my house hile i was doing this, i cant move my car i dont know even who i would call about this. Can someone please help me !!!
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    You wont get a boss kit off without the wheel on it...
    Put the wheel back on the kit and put the nut on a few turns, proceede to hit the wheel either side like donkey kong while lifting towards you with your knees...
    When it comes loose, youll know why the nut is there!
    aZk.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    Finally got it off, had to bash the shit out of !! I'm guessing the Vn boss kit, is different to that of a VP one. From the VP ones ive seen, they had two little prongs at the back, the one they gave me didnt have them..
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    It should have the prongs. Theyre to cancel out the indicators. Some have a tab instead, but they do the same thing.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    collapsable steering can be seriously damaged bashing it like that so don't do it anymore than you have to.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    well when i put the boss on, there wasnt enough room for the nut to go on, so thats why i grinded the tab down a bit. Do you think its possible it may be cllapsed a little, and tht would be stopping me from getting the nut onto the boss?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    With the boss on, was it rubbing against the plastic behind it? Do the splines line up? Can you still fit a standard steering wheel?
    Its sounding like its not a VN/P boss. Did you remove the boss yourself at the wreckers? VR/S boss should also fit, but leaves a gap between the boss and the plastic surround. VL had a different spline. Not sure about pre-VL.
    My (ex)Ride
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    sounds like a vr/vs boss kit on it
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    the boss came straight off a VN, umm what are the splines...?i think im just going to stick with my standard wheel anyways..
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Splines are the 'teeth' on both the boss and steering shaft. They should be a smooth fit without any force until the tapered faces meet and you tighten the nut.
    Im surprised that it stopped the wheel from turning. Something was defiantly wrong.
    My (ex)Ride
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    There shouldn't be a difference between VN and VP at all, all the different stock steering wheels i've had have been identical fittings.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    LUMPY 8's Avatar
    Nov 2007
    Im pretty sure its a vr/vs boss kit cause on them the bit that sticks out behind the boss kit 2 turn the signals off is longer and cause's it 2 rub on the plastic behind it. I know it does that cause im currently using a boss kit i "borrowed" off a mate that was on his vs b4 he slid in2 a tree. Once u cut down the bit at the back there is no difference between them so it should b fine BUT...... i did find it tighter 2 get on and off. Getting it off is easy as... just use a pulley puller.
  1. Bob was in trouble.
    By VS_Pete_1 in forum Jokes/Humour
    Last Post: 18-12-2008, 09:14 PM
  2. In Trouble
    By DOG in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2006, 10:11 PM
  3. Sub Trouble
    By B.C in forum Car Audio
    Last Post: 30-08-2006, 09:09 PM
  4. Having trouble
    By aw006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 07:21 PM
  5. trouble
    By bigazza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-08-2005, 04:01 PM
