Results 1 to 7 of 7
Thread: Thermostat
    89 VN
    Feb 2009
    Smile Thermostat
    hey guys i need a new thermostat but i dint know where the housing is i have a vn s2.
    I've been told it's on the top right hand side do i need to drain it?
    I need a detailed explination on how to do this if possible
    thanks in advance
    Leebo
    89 VN
    Feb 2009
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Its under the thermostat housing aka top hose fitting. 2 13mm bolts and your at it. Will need to drain some coolant, or just catch whats in the top hose and rinse off spills with water.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Leebo View Post
    thanks in advance
    Leebo
    Are you sure you have a S2? '89 vn's have the S1 motor unless it has been changed.
    Either way, follow the top radiator hose to the motor, and there will lie your thermostat housing. S2 they were at the front, on drivers side. S1 were at the back of the motor, under the throttle body which are a pain to do.
    There are plenty of threads already but basically, remove top radiator hose from the motor, unbolt thermostat housing, replace the thermostat and any o-ring/gasket and bolt everything back up. Then you just have to undo the radiator cap and top the coolant back up with the motor running, but it shouldnt have lost much.
    Power is measured in DECIBEL
    89 VN
    Feb 2009
    That's the confusion bit it's had a motor change by the last owner so i think it's a series 2 not that it's anything to brag about but just for maitenence purposes would be handy lol.
    yeah i will give it a crack maybe 2mos after work or on the weekend.
    Did anyone know if i had to drop the coolant?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    You will thank the last owner if they did swap it for a series 2, makes changing thermostats a fair bit easier. No need to drop the coolant, although its a good chance to do a flush and put some new coolant in if it needs it.
    89 VN
    Feb 2009
    That's true i will give it a flush out.
  1. VX V6 Thermostat
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 05:54 PM
  2. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  3. VT V6 thermostat
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2008, 02:07 PM
  4. need a new thermostat?
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 09:23 AM
  5. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
