just wondering if any people using the wade 992a cam could tell me their positives and negatives about its characteristics? cheers.
i'm using one, but in combination with other mods. check my ride thread. good power, lacking down low but that could be the headers a bit too.
checked ur thread, nice vn mate. how does urs go for time 0-100kmh? ive got headers, 2.5 exhaust,KnN filter, cai, 2500 stall, corvette servo, chip[not foamies, asked him, didnt get reply?] changed and checked everything possible but only does 103rwhp and 8.6 to 100kmh?? crap aye! wonder if its the headers lik u said? i wanted the 992a to go with the stall, can u tell me at wot rpms it comes on in urs? even tho u dont have a stall, the info will b helpfull. cheers.
Foam is a busy person, he is also on ebay, 103rwhp sure thats right or is it rwkw, dout it would be the headers but with extractors it gives better top end and you loose abit down low, also from it being a slug off the line could also be the way the cam is dialed in aswell, wade 992a cam will be a good chose its the highest wade cam you can get custom grind for around $220ish, might aswell do head work aswell like powerslave has its also a VP. get the cam and write down everything the car has had done to it and then get foam to do you a tune for it, also another way getting to 100kph is ditching some weight is that 8.6 on the gtech or something? or just counted off the head unit![]()
~ VN POWER ~ Click the scales
its 103 rwhp, and yes i use the gtech pro rr weve done many runs with both cars. my mates vn canes mine not only on the gtech but it has a much more powerfull feel, especially in 2nd gear pull. his only has 2.5 exhaust, lsd, shift kit. and is as thrashed as can possibally be, and gets 7.1 sec to 100. ive had him drive mine and he said it woz definately underpowered compared to his. ive also driven his and i felt the same as him. im going to put the stock stall back in and see how it feels? that prob will b a waste of time, but ive run out of things to check. will go the 992a, but would like to find this lost pwr before camming.
i would start with a good service, get everything up to tip top shape, i just got my gtech today and did a couple runs, not launching it just rolled off line then nailed it, got a 6.05 0-60mph vn v6 charged 4.8psi will try it again today, with better tired on the rear wanna go sub 6
check your compression if you can, could be worn rings
cam timing??
what is the car/engine combo?
125psi is low for a VN buick. a good engine will get 175psi. my VN done a best of 6.8s 0-60mph on the Gtech with absolute shit tyres on the back. check my ride for mods done.
Body by Holden, Soul by Brock
the Legend will live forever
well the manual says a minimum of 690kpa which is 100psi, and mine gets 125 which is 861kpa, at 175 psi its 1206kpa. and my mechanics manual also says 125 when in good cond. please correct me if my maths is out. i just used the conversion table in the manual, and the chart on my mechanics wall to double check. i havent been able to find any info that states more than that.
when i bought my car, all the cylinders showed 170-175psi with only one being lower. 168 or 169psi from memory.
gregories list 689kpa as the minimum cylinder compression. unfortunatly it doesn't list what is the nominal pressure shoulb be. but certainly i'd be woried if it was near the minimum reading
