Results 1 to 11 of 11
Thread: Heater Bypassed for Gas
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default Heater Bypassed for Gas
    As the title says, the heater core has been by passed to feed hot water to the gas setup on the 91 v6.
    Is this normal - or have I had a bodgy job done?
    and 3 Dangerous non ABS VN's
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    not normal. it's more likely the heater was bypassed because it leaks or something. or they were lazy ****s who didn't want to spend the extra $5 putting the right connectors on.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by vlv8vic View Post
    Never had a gas car - so I'm new at this
    So there is reasons for the gas setup to have hot water pumped through the gas thingo me jig. So I'm off tomorrow to find the correct fittings - at least they left the hoses in place.
    Cheers.
    Probably find the heater core buggered - but the car is Ice cold inside.
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    yeah because gas is compressed (to liquid hence LPG) as it turns to gas it gets cold and freezes anything it touches. it needs the warm water from the engine to stop the converter from freezing up and blocking the flow.
    88GreenVN's Avatar
    Jun 2006
    Heater connected - 2 "T" connectors and 5 hose clamps. All done - we have heat
    Morton's Avatar
    Morton is online now For external use only
    Fairstar the Funship
    May 2006
    Well that was easy ^_^ And as vlv8 said, you need a heated gas system. I've driven a car without one, and it used to stall constantly in cold weather
    The 1972 HQ Kingswood
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Morton View Post
    Hmmm car stalled again today - the heater hose is temp at the moment and has a kink in it. I didn't want to hack it up only to find the core was leaking. So that may not have helped
    It's not leaking as yet So I'll trim the hoses up tomorrow and make a neat job.
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    defiantly need hot water as mentioned its a converter so in order to go from liquid ti gas heat is needed you will get the hang of it occasionally they will throw ya a curb ball but its all part of lpg good luck enjoy the cheep fuel oh and be careful about what gas ya put in if its dirty it will wax up the lines and converter meaning a hole lot of work to get it clean again it will also starve because of reduced gas flow
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    Id go back and ask them why they disconnected the heater.
    After all, no heater makes your car UNROADWORTHY since you have no windscreen demister.
    Failing a satisfactory answer from them, id be inclined to report them to the appropriate authority.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by davway View Post
    Hmm, didn't think of that... I was very suprised to find the heater by-passed - for the sake of 2 "t's" and 6 hose clamps.
    Should go find the gas conversion place and quiz them
    Vp series 2
    Jun 2008
    If the ac works then the heater does not have to.
    The ac is a better demister.
    Are your heater lines hanging accross the front og the engine like the ones i have seen?
    That is not a safe place for them to be. I replaced them and run them around the back of the engine and used brackets to hold them in place, A much neater looking job.
  1. Heater Tap
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2009, 07:08 PM
  2. Where is heater tap
    By viper05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-05-2008, 11:31 AM
  3. Heater
    By pj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2006, 09:40 PM
  4. Heater TAP???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 11:16 PM
  5. Heater
    By gospeedracer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2004, 04:00 PM
