Results 1 to 4 of 4
Thread: problem with battery going flat
    richie351 is offline statesman driver n luv it
    VRcommodore
    May 2009
    w.a
    Default problem with battery going flat
    hey guys i have a problem with me vn 5l .. the battery light stays on all the time and sometimes it dies out .. runs fine all day cranks over perfectly normal.. bring it home go to start it in the morning and battery dead flat... i dont know if i using power somewhere.. if i jump start it and go to shop . turn it off and start it again its fine.... plz help
    thanks
    I NOTICE HOLDEN DESIGNED ITS BADGE ROUND DUE TO CIRCLES GO ON FOR EVER..
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    Thumbs up
    Hey mate...
    i had a simmilar problem...
    idd deffenently say it would be your alternator..
    but before you change that because its a bit expensive... rip out the Regulator behind the alternator and you should see 2 tooth like bushes and you would be able to tell if they are worn bacause they would be very short... the problem would be that the bushes are not making contact to charge...
    a regulator will set you back about $50 from Repco.. i think.. i replaced mine not to long ago and my alterator is fine..
    good luck mate.. hope i was some help
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    b4 u go rippin out the alternator do a few checks first.
    Check 2 c if its charging.
    Check the charge wire.
    Check battery and make sure the acid levels r good.
    Make sure all lights r off (check boot light)
    Then of ur 100% sure its the alternator, take it out and check the bushes on the back
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    +1 to checking the boot light isn't staying on
    Check out my VP right 'ere!
LinkBacks (?)
  1. 31-05-2009, 05:45 AM
  1. Flat Battery
    By tr3nt in forum Electrical Wiring / Questions
    Last Post: 31-05-2009, 07:07 PM
  2. battery keeps going flat???
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2008, 01:22 PM
  3. VS-Battery keeps going flat
    By evanthe mac in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 09:14 PM
  4. VQ Battery Going Flat
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 11-07-2005, 04:29 PM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
