Results 1 to 21 of 21
Thread: This ever happened to you - BONNET
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Thumbs down This ever happened to you - BONNET
    Hey just the other day i opened my bonnet, and i hear a crack
    (its my bonnet edge hitting my windscreen)
    the hinges are out of wack
    this ever happened to anyone?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    haha happens to everyone LOL bloody vn-vp's
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Mine touches the windscreen wipers. Looks like you might need to tighten those bolts on the hinges, they could just be loose.
    I used to have an offset, so the hood was more to the left of the car (from the front) tightened the bolts and it was straight again.
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
    haha yer tighten it mate before it causes more damage....
    mine still aint perfect tho.. i have tried and tried but i cant get the bonet to sit properly..
    when facing the front of the car the passenger side near the headlight sits a bit high but.... the otherside is perfect..lol..
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vp do it bad when the bonnet stays need lube
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    busted windscreen from bonnet strike is bent hindges. They get dry and lock. Bend and hit the window.
    Newies are the only way. Oh and a new window
    and 3 Dangerous non ABS VN's
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Yeah same thing happened to me about this time last year, 80 each for the hinges, and apparently that was heavily discounted, dayumn. Windscreen was only 180 though, it's handy knowing people.
    Should we be doing something about keeping these lubed? Just a quick shot of WD40 at service time?
    Check out my VP right 'ere!
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by camstatic View Post
    change engine oil - squirt hinges
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by 88GreenVN View Post
    LOL yea, +2 hinges later.....
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Vp series 2
    Jun 2008
    mate it has happened to me a few times.
    lube bonnet hinges at all four pints then work it back and forth a bit till smooth.
    take bit off the bonnet and bend it.
    the arm is ment to be angled down a bit so just bend it and repaint it then stick it back on.
    just remember to lube hinges and struts occasionally.
    89 VN
    Feb 2009
    COMMODORE VP
    Dec 2008
    lol i see it is a regular thing, yeah i replaced hinges
    and all good, you cant get it perfect unless you replace them, and the windscreen grr after the damage
    thanks guys for confirming it
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    my bonnet did something else retarded
    the release lever broke at the drags... couldn't open it . stupid VNs :P
    and my hinges are wobbly as anything.
    WTB: mulberry VN interior parts
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    You need to fit bonnet struts and brackets from a later model car(vr/s)...at the lower end the small ball joint bolt bracket goes under a bolt that screws into one of the guard attaching holes and you have to make a small plate with a nut welded on to for the ball joint stud to screw into on the other end and drill a couple of holes on the inner frame of the bonnet ...there is a space there for it just no hole...then as you raise the bonnet the gas pressure pulls the bonnet forward and the rear corners clear the windsreen easily...no more unnecessary windscreen replacements..worked for me....and the stay bar you can take off and throw away...I welded the holes up.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  15. #15
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
  16. #16
    89 VN
    Feb 2009
    Quote Originally Posted by COMMY VP 666 View Post
    yeah lol i got new hinges 2, actually changing them over was how it happened i want VP gas stuts
  17. #17
    VP Exec
    May 2006
    Bugger, this has just happened on my vp, passenger side only, so it seems I'm up for a new hinge and of course the window. All I did was close the bonnet from the drivers side, not the middle and now this!
  18. #18
    VP Exec
    May 2006
    All I needed was the bracket, cost me $6 today and sprayed the hinges with wd40 and voila all good
    Now all I need is a new window, I've been quoted $262 with o'briens, anyone from Adelaide know a cheaper place to get one fitted? I might have to wait til tuesday to ring around...
  19. #19
    social's Avatar
    social is online now Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    $262 and they come out to you? thats a good price man prices vary from 300-450 callout.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
  20. #20
    VP Exec
    May 2006
    I live like 2 mins from o'briens on marion rd though...by the way it sounded on the phone they said its $262 if they come to you or even if you take it to them, same price? Maybe it's as I am close?
    I was just reading further up people paying $160-$180 for the window and was wondering if anywhere around Adelaide does them closer to that price...
  21. #21
    skruba is offline holden, honda, pitbulls
    vp executive
    Jun 2009
    parkes nsw
    arghhhhh its happened to me to lucky for this thread a quik read up n im set cheerz lads
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. what just happened :S
    By Rg123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 05:12 PM
  3. What happened to this car?
    By peninsulabands in forum General
    Last Post: 10-05-2007, 10:43 AM
  4. ever happened to anyone..........
    By Jenga73 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2006, 01:21 PM
  5. What Jus HappEned...?
    By StealthX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2006, 03:52 AM
