Results 1 to 4 of 4
Thread: VP Buick V6 problem
    VT
    Apr 2009
    Default VP Buick V6 problem
    Hey guys, I have a 93' VP buick V6.
    problem: I come back to my car 10-20 minutes after having driven it home from work (1/2 hour trip). when I start it, it idles at a very low rpm and fluctuates up and down id say between 400-800 rpm.
    I then put the car into reverse and it stalls more often than not, id say 3 times a week this would happen.
    Ive recently had it serviced and cleaned the throttle body/air filter. The mechanic said "come back and see me when its happening constantly" - no real help there.
    I've heard it could be my IAC sticking or my thermo playing up not letting the car reach running temp etc. If it is temp related I might as well mention that last summer she overflowed a bit of boiling coolant yet it didnt display any real increase on my dash temp gauge.
    If this has happened to anyone else please let me know how you fixed it, or ill just take her back in to the mechanic.
    cheers guys
    [CENTER]CRAWJP - VT
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    id say its ur IAC, mine was playin up like this, full can of throttle body cleaner n she all good.
    Does ur temp get up 2 running temp , ie the first notch on the guage, if it sits on the bottom after a good drive then u will need to change ur thermostat so it keeps tha car at running temp.
    If its on cold the ecu riches up the air/fuel ratio making it run hotter to get to the running temp faster
    ________________________________________
    VT
    Apr 2009
    thanks mate, ive given the TB a good clean, and still no good, surges, stalls, my temp guage sits on about 1/4 on a normal drive - home from work etc. but has never risen to more than 1/2 way even when it overheated.
    is there a way to specifically clean the IAC without wrecking it?
    cheers
    [CENTER]CRAWJP - VT
    VP Executive R-spec
    Jan 2005
    Should be either the tps or iac, I'd tell you more about it if I wasn't so sleepy , maybe tomorrow
LinkBacks (?)
  1. 07-06-2009, 02:43 PM
  1. vn-vr buick
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2009, 03:00 PM
  2. buick v6.
    By VRV6BT1 in forum V6 Development And Modification
    Last Post: 16-04-2008, 02:11 PM
  3. buick heads?
    By vr_owner in forum V6 Development And Modification
    Last Post: 06-03-2007, 09:02 PM
  4. VH Buick 3.8 Help/Q's
    By pro_gmh in forum General
    Last Post: 24-02-2006, 05:58 PM
  5. Buick 3.8l
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2003, 08:18 PM
