Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Hints / tips wanted: floor restoration
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Arrow Hints / tips wanted: floor restoration
    Ripped up the carpet in the VN, in the cabin and the boot. I have decided that the sound deadener is coming off, probably both sides, and the floor will be finished in a nice clean coat of white paint.
    There is a hell of a lot of prep work to do first.. just wondering if anyone can offer any advice or has undertaken a similar project in the past.
    At the moment the plan is:
    Chisel off deadener pads from inside cabin
    Finish floor with wire wheel
    White primer (many spraycans )
    Alpine white - again probably spraycans, not sure how many coats I will need and therefore whether it will be worth buying a decent spraygun
    Clear??? - want a good finish that can be polished if needed....
    Someone tell me if I'm completely off the mark..
    Sam
    WTB: mulberry VN interior parts
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I have decided I'll need a spraygun for this job. Much cheaper that way.
    Vp series 2
    Jun 2008
    Why?
    Why would you do that, vn's sound like you are riding in a tin can at the best of times.
    Removing the deadener would make it a real uncomfortable car to be in.
    I dought you would have many people want to get in it a second time.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by centy View Post
    Why?
    its a vn, why would they want to get in it the first time!!
    for the deadener, goto bunnings and buy a $20 heatgun, and a scraper.
    or, ive seen people have success with dry ice, which is supposed to take the glue off with the deadener(heatgun doesnt do this)
    get a lot of prepsol or thinners for cleanup its gonna get messy
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks guys
    Centy, because there is weight to be saved! Nobody refined ever rides in my car anyway man
    **hopes mrs doesn't read this thread**
    I'm hunting for kilograms to ditch. The car will end up being essentially track-spec, aiming for a stint racing later on
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    VP Executive R-spec
    Jan 2005
    I think hes aiming for the shiny clean race car look, inside and out. Carpet is just old stinky wet dusty dirty mould and virus infested chemicals in the end once you've spent 2 days scarping deadner off you'll realise how evil it is to produce that is too let alone stick it in every car Holden make. I salute Ford for having none in the new eco freindly euro cars. Sure they make a bit of noise bit it's well worth not having it in the car for the weight/fuel/world saving, it's very responsible. P.S only remove the deadner not the calk in the seems since that's all that holds a Commodore together really is that glue
    Morton's Avatar
    Morton is online now For external use only
    Fairstar the Funship
    May 2006
    Savage, paint the floor with a big tin and a brush/roller You'll save a lot of money (pressure packs are expensive), and it'll come up fine!
    The 1972 HQ Kingswood
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by greenfoam View Post
    You're right that's exactly what I'm aiming for. I'm glad somebody understands my newfound hatred for body deadener! I will be careful of the caulk, I hadn't thought of that
    Quote Originally Posted by Morton View Post
    That is not a bad idea. Now I just need someone to tell me what primer to use
    I've actually been thinking HVLP gun rather than pressure packs, still better to go roller or brush you think Morton?
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    try and get dry ice, its makes it piss easy to do all seems to come up in big clumps rather than tiny little pieces.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    Vp series 2
    Jun 2008
    roller would be better thin the paint a little and you would get a good finish and not overspray.
    to reduce weight remove ac, line doors with a thin sheet of aluminium. remove the metal mouldings around the doors on the outside.
    upgrade to a vs brake booster, they are plastic.
    Make sure you have the small vn brakes on the front a they are smaller and lighter.
    all these would save weight.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Seeing as he wants to race the car, I don't think small brakes are much of a reccomendation Is it really worth the weight saving?
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Or even better sand blast it? depends how deep you want to go.
  15. #15
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Talking
    its a pain in the posterior i did my first vp race car with a heat gun and scraper and will be doing my new vns1 the same way soon as Jason said its bad stuff if you use a heat gun make sure your in a well ventilated area with the windows down and yeh get some thinners or petrol to wash ya hands with after its as hard to get of skin as it is metal especially with just soap and water have fun
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
  16. #16
    Morton's Avatar
    May 2006
    1) The best thing to get off the last of the residue, is acetone. Lots of acetone. I'm pretty sure a wire brush will just smudge it.
    2) Prime it with a good outdoor rustproof primer. White Knight do a good primer for a decent price, and a 1L can should get you two coats all over.
    KEEP IN MIND: If you use 2 litres of paint, that's 2 kilos of weight
    I suggest you use acetone on the deadning, which leaves the factory rustproofing intact. Then fish oil the whole thing for rust protection, and once it's dried up, give it one or two coats of White Knight Rustkill Hammertone paint. That stuff does NOT need primer, so you save on paint weight
  17. #17
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Doesn't need primer..........ever read the label or only the front of the can All non-ferrous metals need to be primed with etch primer, so aluminium and its alloys.
    Unless your VQ is made from cast iron.........which would account for the extra weight, lol.
  18. #18
    '97 Lexcen Wagon
    Sep 2007
    Perth, WA
    Quote Originally Posted by savage1987 View Post
    *mrs reads thread*
  19. #19
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    LMAO!
    aaaah shit
    Thankyou morton and company for your input
    I will get the deadener off and then decide what I want to do about paint.
  20. #20
    VP Executive R-spec
    Jan 2005
    Forget the fish oil, this is a race spec floor not an old cargo ship, get the deadner off and clean as you can without damaging the zinc or whatever the sheet metal is coated in, then use dexodine to be sure the surface is clean and any rust particles are disolved. Then paint it. Since you wont be using two pack (would have been good on the floor) just use a primer and white acrylic, then it will be easy to polish up and plenty waterproof enough to last about forever
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks Jason
    Heat gun and some thinners and a mask will be coming home with me tomorrow I think.
  22. #22
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i just did it the cheap way and used a chisel, sore hands for some days just get a mate around to help, i think its a good 20-30kg or something in deadner, atleast not sure cant remember, but the sound difference isnt that bad to be honest i didnt notice a big difference, but i am use to it now, but people make it out to be real bad and everything.
    ~ VN POWER ~ Click the scales
  23. #23
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by Bz Kn33z View Post
    yeh, going from carpet+deadener+thick foam underlay to metal floor and a thin coat of chassis black on the bmw wasnt too bad. can hear everything hitting the underside, but overall sound isnt too bad during cruising.
  24. #24
    VP Executive R-spec
    Jan 2005
    Thanks Jason
    Yes just don't use the heat gun anytime soon after the thinners or you would be inside a very unhappy fireball
  25. #25
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    hehe just light the thinners up or as jason said cut out the floor pan and remake it from clean road signs
  1. Holden: Hints of Torana
    By CSP in forum News/Updates
    Last Post: 11-02-2009, 11:04 AM
  2. Wanted Vr/vs Floor Interior Carpet
    By janhdt in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2008, 10:05 AM
  3. HID Conversion on VT Hints.......
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-11-2007, 11:29 AM
  4. Replacing Tensioner...any hints?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2007, 10:41 PM
  5. Exhaust Tips Wanted
    By ULOOK-2 in forum Swap / Wanted to Buy / Trade
    Last Post: 30-11-2005, 04:55 PM
