I'm trying to install an amplifier, but I can't seem to find the rubber gromit to pass the red cable through, can someone help me?
If it's an automatic, poking a hole through the clutch grommet would be ideal.![]()
Check out my VP right 'ere!
Ok thanx, Yer it is an auto, do you have any pics so I no wat I'm lookin for
get your head in under the dash and look at where the clutch pedal might go, you will see some furry material circle behind a black plate, get that stuff out and the grommets past that.
or just look to the right of the brake booster from in the engine bay for the oval looking grommet.
have fun getting the grommet back in. (you need to remove the grommet to cut a hole, because its about 8mm thick)
Hey guys thanx for the help, that's exactly wat I did, I got em connected now and it sounds awsum;-)
Thanks again, it saved me $150
