Results 1 to 7 of 7
Thread: Is there a difference between VN - VP - VR - VS steering racks?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Is there a difference between VN - VP - VR - VS steering racks?
    Vp series 2
    Jun 2008
    Morton's Avatar
    Morton is online now For external use only
    Fairstar the Funship
    May 2006
    The ones I've worked on have all looked fairly similar. If anything, the hoses may plug to different locations, but I doubt it.
    Same rack width, same mounts, same steering lock, same pump style.
    The 1972 HQ Kingswood
    Vp series 2
    Jun 2008
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Okay Dokey!!!
    VP Executive R-spec
    Jan 2005
    VN and VP are different on the shaft, I'm not sure if the VR and VS are the same as the VP rack but they could be
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    the length from end to end could be a little different, but this can be adjusted at the tie rod ends so is not a problem.
  1. VN and VR Steering racks
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 10:47 PM
  2. Steering Racks
    By wickedVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2008, 07:09 AM
  3. steering racks
    By defa in forum General
    Last Post: 06-01-2007, 11:55 AM
  4. VN / VP Steering racks?
    By Pretender in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 10:08 PM
  5. steering racks
    By londongeezer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2005, 08:44 PM
