i went for a cruse up mt hothom today and for some strange reason the car would stall every time i went threw a right hand bend anywhere over 40 km per hour i checked all the leads sensor plugs ect i cant figure it out anyone have any ideas i might add that it was on gas and i had a full tank
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
It sounds like your car was starving for fuel on right handers. What was the fuel level at the time? You could have a problem with the fuel pick-up in the tank.
Another alternative is loose wiring connection to the fuel pump, which allows movement in right hand bends and breaks the circuit. Check fuel pump wiring circuit, starting at the pump connection on the tank and work forward.
it was on gas and it was full
what no one else got any ideas ?
I'd say loose electrical connection somewhere? Maybe? As soon as you said 'gas' I lost my train of thought.
Check out my VP right 'ere!
it was the cas the little notch on it to lock the plug onto it is gone so every time i went around a bend it would come off just enough to make it stall
good oh a win for a stalling VN/VP![]()
and 3 Dangerous non ABS VN's
lol i hope that was it i didn't have any issues today but it was normal straight road driving ill see tomorrow ill hit some roundabouts hard and find out![]()
it was defiantly the cas i put a mark on it today and hit a few roundabouts and sure enough it stalled again checked the mark the plug had moved out again
i just put a dob of silicon on it to keep it in place until i go get my spare cas of my other vp
