Results 1 to 3 of 3
Thread: Starting problem
    VP Executive S2 shit box
    Jun 2009
    Penrith Nsw
    Angry Starting problem
    Hi everyone... ive been having a problem with my vp, and its probably the most annoying thing. It has new spark plugs, new leads and a new battery, sometimes the motor wont start. The engine is kicking over but it is not firing up. This problem happens more often when i buy fuel for it, if that does help. Today my car is at the servo which i had to walk from as it did not start. Other times when i start it and it does this, i leave it for about 10 minutes and it starts good, but today that didnt work, so i am really piszed off .
    I really need some help in wat the problem could be... thank you
  2. Default
    i think the crank angle sensor (cas) often brings about this problem. you can try pouring some cold water over it? if your car starts, then the cas would be the culprit.
    Quote Originally Posted by zai View Post
    I am not sutpid
    VN Lukey's Avatar
    VN Lukey is offline BT1, the way to go
    Holden VN S1
    May 2009
  1. Problem with starting car.
    By MG's VH Wag in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-10-2008, 07:57 PM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. VT Starting Problem
    By Waynus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2005, 11:35 PM
  4. Vs Starting Problem
    By Darren in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2004, 08:08 AM
  5. Vn Starting Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2004, 02:03 AM
