Results 1 to 19 of 19
Thread: Brake:Bleed
    VT SS 5.7
    Mar 2005
    Goulburn
    Default Brake:Bleed
    Anyone got a Part number or know the size etc for the brake caliper front and rear bleeder nipples.
    Also Stocky Diff vs LSD waht are the good and bad of both
    Real cars don't power the front wheels, they lift them
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Pros:
    open diff: very cheap, less frequent service intervals, safer for noobs
    lsd diff: towing heavy loads, safer for experienced drivers
    The 1972 HQ Kingswood
    VT SS 5.7
    Mar 2005
    Goulburn
    So would there be much HP gain to wheels with a lsd noticable or little?
    Morton's Avatar
    May 2006
    None, it has nothing to do with horsepower. If anything at all, you would lose the tiniest immesurable fraction through rotating mass and mechanical friction.
    VT SS 5.7
    Mar 2005
    Goulburn
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Why aren't LSDs safe for noobs? More likely to lose the back end under power?
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    while this threads going, can anyone recommend where i can get some copper washers for the fronts? i got 'champion' brand ones from autobarn.
    the 3/8 ones have too small inner diameter to fit the banjo bolt, but the outside diameter fits the hollow on the caliper
    the 7/16 ones have the right inner diameter to fit the banjo bolt, but the outside diameter is to big to fit the hollow on the caliper.
    Morton's Avatar
    May 2006
    Quote Originally Posted by maldotcom2 View Post
    Pretty much. A single spinner lets you know when you've given it too much boot in the rain, and you can back off. An LSD will throw you sideways pretty much instantly - and in a car with stock suspension, that can be scary for ANYONE at 80kph.
    Conversely, if you drive like a chopstick and keep your foot booted all the time, a single spinner is going to do something unpredictable at some point, and throw you into a wall. An LSD will always react in the same way, so you can at least brace yourself for the impact.
    Quote Originally Posted by pow3rslave View Post
    Take a sample washer into Burson and they have packets of them everywhere.
    Jul 2008
    I like it morton haha !
    OK in " chopsticks" terms
    Open center = crap single wheel skids unless you get em spinning fast enuff or your dif is just ****ed or welded up :P
    LSD, great for going sideways and laying 2 lines of rubber instead of 1 !
    I hope thats easy to comprehend...........
    But as morton said, lsd + wet = dangerous for the novice driver
    and allso cheap parts for me
    Morton's Avatar
    May 2006
    Also just note, cheap/old lsd + wet + good driver = dangerous anyway Sometimes worn LSDs aren't as predictable as you'd like
    Vp series 2
    Jun 2008
    mate 2 different size bleed nipples on the front of vn/vp's best bet is to take one into a shop and match it. to not drain all the fluid clamp a brake line with a pair of vice grips.
    VT SS 5.7
    Mar 2005
    Goulburn
    Quote Originally Posted by centy View Post
    Hey mate , did just that and no place here where im located can tell me a part number or even match them up with others kinda at a dead end so far. still trying to fidn a part number or where to get them from(vn S-PAC V6 FE2) Aka Vn V8 brakes
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    genuine maybe?? You got a dealer near you
    Reaper
    Dec 2008
    Quote Originally Posted by Morton View Post
    True that. Any easy way to tell if it's getting worn and needs new cones?
  15. #15
    Morton's Avatar
    May 2006
    Peg it around a tight left hand corner. If it singles, it's getting old
  16. #16
    Vp series 2
    Jun 2008
    vn fe2 nipples i think are the same on series 2 vp/vr/vs.
    Try the wreakers for them.
    how many do you need?
    I might have a old one here.
  17. #17
    VT SS 5.7
    Mar 2005
    Goulburn
    yea i tryed the local Holden dealer they claim they dont make or sell them anymore, only after the front to nipples since the old owner of my car thought it be fun to strip the 10mm nut on the bleeder
  18. #18
    pow3rslave's Avatar
    VP 5.0L
    Oct 2005
    eastern subs, vic
    mine had different ones from one side to the other.
    so i kept the two long ones and have the short spare.
    i can mail it to you if you want.
  19. #19
    Vp series 2
    Jun 2008
    long one are on early vp's short on vr.
  1. 5L Bleed Screw - Where is it?
    By levymetal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2009, 01:09 PM
  2. Where is the Bleed screw?
    By Phantom VK in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2009, 09:44 AM
  3. How to bleed brake lines
    By policehoon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2008, 11:23 AM
  4. bleed nipples
    By Wire in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 07:41 PM
  5. Brake Bleed Nipple Stripped
    By Demons1964 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-01-2006, 03:14 PM
