Results 1 to 15 of 15
Thread: VPs with IRS
    VP Berlina S2
    Jun 2009
    Default VPs with IRS
    I was on Wheel king looking at rims and it said that you cant put VT internationals on VPs with IRS. True?
  2. Default
    i don't see why they wouldn't fit straight on, and i've seen plenty of calais with internationals. [click]. maybe they need spacers or machining?
    Quote Originally Posted by zai View Post
    I am not sutpid
    Jun 2005
    partly true. VP IRS have a different offset or something
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    /\ correcto, VP with IRS are the only one to have a different offset. Either use spacers/longer studs (i have this for my grange wheels) or do the simple fix of changing to VR onwards hubs (which is what will be on the cards when i can be bothered)
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  5. Default
    ergh well i was wrong wasn't i... do you have to use the longer studs with spacers?
    I am not sutpid
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by levymetal View Post
    Only if you don't want your wheel coming off doing 100ish in the hills
    I got out of it cheaply, bit of paint on the valance, 3 snapped studs. Ended up getting 10 brand new longer ones.
    http://i145.photobucket.com/albums/r...r/102_0012.jpg
    cheers sexy
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    be a nightmare for insurance with wheel spacers yes/no!
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Well spacers are illegal to start with, so you'd imagine so.
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    the VT to VZ wheels sit about 15mm closer then the VP IRS, the VP IRS off set is 28p and the VT onwards is somewhere around 40p-45p im not 100% sure, all depends on tire width to weather there 245's or 235's.
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Pretty much in lamans terms, the VP arse ends are skinny as shit!
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Da_rooster1980 View Post
    Depends how often you need insurance i'd assume About as legal as a full spool haha
    cheers sexy
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by tr3nt View Post
    With the proper wheels they came with (that no one has anymore) they are actually wider then the non IRS car, both front and back
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Jason, I still have my 15's they're in the garage! I mainly went for the bigger rims for two reasons: I had the money at the time, and I lost an International centrecap.. It was easier to buy the rims than get another cap
    VP Berlina S2
    Jun 2009
    Would RTS have the same problems? I doubt it but I just wanted some confirmation.
  15. #15
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VP KC View Post
    Nope, the offset change was only on IRS cars.
    cheers sexy
