Results 1 to 17 of 17
Thread: best way to flush an engine
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Question best way to flush an engine
    whats the best way to do an engine flush ive been told 1 part diesel to 5 parts fresh cheep oil and take the fuse out so it dont fire and just crank it a few times then drain what other ways are there just theirs a service coming up and seeing i dont know the full history of the car id like to flush it ?
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    89 VN
    Feb 2009
    Nor sure what's the best way but don't use that shit from autobarn it will ruin the seals in the motor needing a rebuild as a result.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Jun 2008
    golden beach
    Quote Originally Posted by Zuicider View Post
    instead of diesel use trans mission fluid
    serious ?????
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    ive never done it, but i though thats what that nunlon engine flush does?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Set of thongs
    Dec 2005
    Stonedville
    whats the point of an engine flush if u cant get it going through all the ports and with a bit of heat
    Jun 2008
    golden beach
    well ive had 1 v6 die from buildup and sludge already id like a way to pre empt that and it wasn't because of me it was past owner not maintaining the thing right
    vn calais, vs clubsport #137
    Jun 2005
    ive always used diesel, but ATF will do fine, get the oil nice and warm then add ur diesel or additive and run it for a bit and drop the oil while its hot.
    Jun 2008
    golden beach
    Quote Originally Posted by vn calais manual View Post
    thanks sounds like what i was told was the best option and thnks for the make sure its warm tip
    and thanks Zuicider for the atf tip
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    so is it warm car, add diesel, dump it when it's hot. add new.
    is there a point in the cycle to change the oil filter
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Don't know about ATF/diesel, but with the bottled stuff (Nulon etc) you warm up the engine, put the stuff in, run it for about 20min (just idling, IIRC it says don't put the engine under load by driving it) then you drain the oil as normal, at which point you change the filter.
    Mainlube also make a "flushing oil" where you drain your oil, put that stuff in, run it for a while, then drain again and change filter.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Jun 2008
    golden beach
    im assuming that i would put it in cold and warm it up i dont think i like the hole pouring diesel into hot oil my self and im aware it has a high combustion rate but i still don't like the idea so from a cold start until warm for me
    VP Executive R-spec
    Jan 2005
    You can also run a super high detergent desiel oil like Mobil delvac, that will slowly clean it out
    Jun 2008
    golden beach
    i dont need it like a never run before car just cleaner than as if was driving it for ever without a good quality oil
  15. #15
    Set of thongs
    Dec 2005
    Stonedville
    another is to fill the car with thinners so thinners are coming out the top then flush it out with water
    hehe mate almost fell for that one, lucky i got there jsut in time
  16. #16
    Jun 2008
    golden beach
    now thats just stupid lol who even comes close to believing thats the way to go lol
    i must admit i was told a classic use roundup drive the car for 15 min the problem is the roundup and oil have a interesting reaction the chemicals in the round up bind into almost perfect solid ball bearings you can imagine what happens next lol
  17. #17
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    No matter what do not use a flush on an anything above 80,000k's ! Do as Greenfoam says and use a CI-4/SL rated Diesel oil like Delvac mX or Repco Diesel and use that to clean. Even better is to use a product called AUTO-RX. Order in from the U.S and dollar getting stronger ( I got mine in when we were 92 US cents), or if you really want some i can get you some sent from a Oz distributer and euro engine builder. He's not an official distributer, but orders in boxes of the stuff for his workshops, mainly does performance mercs and BMW's but a very good bloke. It cleans slowly over period of time, not just a quick flush that first of all can dislodge bigger stuff to block a gallery, but cause compression loss issues, seal issues etc.
    http://auto-rx.activeboard.com/index...picID=22835840
    http://lubecontrol.com/lube.htm
    http://www.auto-rx.com/
    It seems if you have always used a solvent flush then it should be ok (still with seal damage potential), as your engine it mostly always clean. BUt when neglected can be some nice suprises. The VN seems to be a dirty lil engine if not looked after possibly due to its venting/breathing mechanism.
    There are 2 products with high acclaim and proven to work in majority of situations Auto RX and LC-20. For example in my vehicle, i had no top end sludge due to my oil regime that i could see anyway, but after cleaning, increased compression, the engine runs much better, as it cleans up around the ring area. LC-20 is also very good but expensive to get in here.
    http://www.lcdinc.com/tests_dyson.php
    http://www.auto-rx.com/pages/testing.htm
    THe above is by Terry Dyson, he is an oil gun (one of the best oil specialist in the U.S), pilot, used to be a racing car driver. If he endorses these products should be good enough for anyone.......
  1. Engine oil flush/injector cleaner
    By kmbattle in forum LSx Development and Modification
    Last Post: 01-07-2010, 08:23 PM
  2. engine flush
    By helrzr925 in forum General Discussion
    Last Post: 28-03-2009, 01:18 PM
  3. I Had to Use Engine Flush Again
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2008, 02:07 PM
  4. Engine Oil Flush
    By fullaaa in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-02-2008, 01:33 PM
  5. Saving $$$ with engine flush
    Last Post: 07-07-2006, 07:22 PM
