OK well i ran all the cables to the amp n it worked fine
i had the active (rem) going to the lighter
so then i moved amp around set it all up n its not working
so i trying puting the atcive wire(rem) to the foglights active wire to see if it was tht n it didnt work
wat the hell shud i do ir check cheers
