Results 1 to 8 of 8
Thread: Damn thing dosent start right now?
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default Damn thing dosent start right now?
    I replaced my battery about a month ago, with a new 460CCA one. All was fine, until about a week ago. First it wouldnt start, battery was flat after i drained it playing the Stereo for too long waiting for the Mrs to come out of work. So jump started it by NRMA, who also said the alternator is fine. Then a few days later, it went flat again, and i hadnt been using anything. NRMA said it was just loose at the terminal, and that the battery was fine, as to the alternator. And now, when i go out i the morning to start it, it makes a clicking niose, instead of turning over, and i have to keep messing around with the key, until it fires up..then when it starts, i have to keep the revs up, for atleast a minute, otherwise i just dies. and it doesnt splutter or anything when it dies, its just instant, revs drop completely and then its gone. I dont know what to do as NRMA keep telling me its fine. My car used to start first time everytime, and never skipped a beat the whole time i've owned it. Is my engine going to car heaven ???
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    The clicking is a relay, and you get that sound when your battery is indeed flat, but obviously yours isn't. So it's probably a simple loose connection somewhere, but NRMA are only good for the basics.
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    any ideas what i could check, because yeah it only started happening all of a sudden...
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Sounds like a dodgy starter solenoid to me. Verify this by checking battery voltage when it won't start with a voltmeter, how many is it reading?
    Check out my VP right 'ere!
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    i had this problem with my new vn s1 race project turned out the earth to the motor/engine mount back to battery had a heap of oil and dirt at the engine end the only way it would start was by jumping it and after tare assing about in a paddock it wouldn't even click it just did nothing unless the jumpers was on it
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Fun_Bucket's Avatar
    Mar 2009
    Cairns White Rock
    You mentioned engine mounts, i recently had mine done, could they have stuffed something up? I'm thinking of booking it into Ultra tune shortly, as it has a slight missfire at idle, which i want to get fixed, so hopefully they can look into it for me..
    Jun 2008
    golden beach
    Quote Originally Posted by HoldenCommodoreVP View Post
    that can also be caused by not having a full earth as well mine had a slight miss before i fixed that now its gone that's all ive changed so i assume that's what caused it and its possible they didn't file the paint off where they bolted it to ie the engine mount
  1. In car DVD that dosent need handbrake on!
    By mrvx2 in forum Car Audio
    Last Post: 16-05-2009, 04:29 PM
  2. The damn thing won't get louder !!!
    By Psycoss in forum Car Audio
    Last Post: 09-05-2009, 07:00 PM
  3. Torque converter dosent fit into manual crank
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2007, 12:27 PM
  4. Doesn't want to start....damn it
    By Murmur77 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 09:23 PM
  5. Im buying a VL executive and it dosent start.....
    By jonosVSacclaim in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-10-2004, 03:37 PM
