Results 1 to 3 of 3
Thread: Wiperblades
    1989 VN Calais
    May 2005
    Default Wiperblades
    hey guys, i need help trying to get my wiper blades out, i need to replace the blades and metal backing leaving the arms, i can't get the whole blade section off though
    does anyone know how??
    do i have to take the pin out that goes through the middle??
    i have no idea
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    im just gonna laugh at this one ....... someone else can help the poor mite!
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
    VpV6 is offline Banned
    VP II Executive
    Feb 2005
    If you just wanna replace the blades (ie the rubber bit and the metal bit behind it) here is what u do:
    1) Lift up the wiper arm so it clips up away from the windscreen (like when u wash your window).
    2) Have a look at each end of the wiper blade. One end will have a clip on it which stops the blade from pulling out. Some of these clips are silver and some are black, it depends on the brand. Get some pliers and squeeze the clip. (You should see two little 'paddles' that you squeeze up) At the same time pull the blade away from the arm and it should come out.
    3) Refit the new one!
    Hope this helps out.
