Results 1 to 10 of 10
Thread: vn 3800 rebuild help !!!!
    vn executive
    Feb 2009
    frankston
    Default vn 3800 rebuild help !!!!
    hey guys i have just pulled my motor our of my vn due to welsh plugs and i was just wondering what other stuff i should do to my engine why it is out and how hard are head gaskets to do on them the things ive thought of so far is.
    welsh plugs
    valley seal
    rear main seal
    head gaskets
    rocker cover gaskets
    sump gasket
    thanks guys im a second year aprentice so it shouldnt be to hard thanks
    VN S1
    Jan 2008
    Valves and springs should be done while you got it out. Maybe even timing chain.
    VN S1
    Jan 2008
    Also if you buy a vrs gasket kit it will have nearly every gasket to do the motor.
    vn executive
    Feb 2009
    frankston
    thanks man um where do u get the vrs kit the endinge has done 380,000 km and its on gas to so how much are valves and springs thanks
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Must do the timing chain tensioner - must!!
    and 3 Dangerous non ABS VN's
    VN S1
    Jan 2008
    Most brands have vrs kits, just ask when you go to order a set. I got my vrs acl tace series for 250 i think delivered.
    vn executive
    Feb 2009
    frankston
    VN S1
    Jan 2008
    230 about for gaskets, 30 for timing chain tensioner, Or off ebay you could get all you need for 300.
    vn executive
    Feb 2009
    frankston
    88GreenVN's Avatar
    Jun 2006
    Also when the timing cover is off - look for corrosion behind the water pump outlet. I've had 3 Vn motors leak from behind this point.
  1. To Buy or Not To Buy?? SV 3800
    By samh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2009, 02:29 PM
  2. vp 3800 s2
    By vp_ex_no_boost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 09:41 PM
  3. The 3800...
    By JacoReborn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 01:25 PM
  4. 3800 fit
    By vp_s-pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2006, 10:29 PM
  5. To rebuild or not to rebuild!? advice needed
    By Jason1987 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2005, 08:36 PM
