Results 1 to 14 of 14
Thread: temp gauge on vn
    commodore VX SS SII
    Feb 2009
    adelaide
    Angry temp gauge on vn
    Hi, need some help with my temp gauge. I just put a new radiator in (natrad) new water pump, new intake manifold gasket's , new thermostat, 2 new temp sender on the intake manifold. Now the temp gauge in the car read's 1/2, but before I did all this the temp gauge read 1/4, is this the right temp? Or is it too high? The thermo fan come's on at 3/4 and cool's it back down to 1/2. Was told today you can run a colder thermostat, can anyone inform to weather this is true or not...
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Is the car getting hot tho? Can you squeeze the hoses?
    It may just be a dodgy thermostat, blocked water jacket, or that the gauge is now reading correct.
    The gauge can be tested using a multi meter - but how I'm not sure
    and 3 Dangerous non ABS VN's
    commodore VX SS SII
    Feb 2009
    adelaide
    can squeeze the hoses, also replace the temp gauge as that's what i thought it was. sorry not sure what you mean about water jackets. spoke to a guy at auto pro today he said the temp is fine. And the car should run 1/2 way. I'm so confused
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Temp gauge is exactly that....its a gauge. Can you tell me what temp the water is at 1/4 gauge reading and what temp the water is at half? It may only be a few degrees different if that. Only way to find out is to get into the computer via holden and check what the coolant temp is at when reading halfway. I think you will be surprised to find that between half and a quarter there is barely a couple of degrees.
    commodore VX SS SII
    Feb 2009
    adelaide
    thanks for that it make some sense now. was told you can get two thermostat one runs 15c cooler thanks for your help
    88GreenVN's Avatar
    Jun 2006
    The gauge is adjustable too - has a slider adjustment at the back of the gauge.
    Have you tried the old gauge back in the car?
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Don't get a cooler thermostat. No need whatsoever. I have a 500hp VL Berlina Turbo which sees street duties with air con and it has standard thermostat. I just sold my VS S Pack SII V6 Commodore and that had standard thermostat.
    With a fully serviced cooling system, there is no need to stray away from the stock standard genuine thermostat. After I serviced the VS and complete cooling system, the gauge occassionally played up and went to 3/4 mark. My best mate at the auto electricians put the hand held computer on it and even when the gauge rose to 3/4 mark, it wasn't in any danger of getting too hot.....exact figures are unknown as it was 3 years ago when we did it. The car went perfectly and no overheating for 3 years of owning it.
    social's Avatar
    social is online now Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    and i was just going to ask the simple quesiton of did u bleed the cooling system and have the heater on while doing it..?
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    commodore VX SS SII
    Feb 2009
    adelaide
    yep bleed the cooling system i might run a over ride switch on the thermo fan. found a post on here do you think it's a good idea?
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    There is no way that anyone would be able to switch a fan on perfectly at the correct time everytime the gauge rises......unless you are stationary and you recline your seat back a little and you get some popcorn and a drink and you are sitting in your driveway staring constantly at the temp gauge
    Go to an auto electrician or holden dealership and get the tech 2 hand piece on the car and let them tell you the water temp when the gauge is reading 3/4.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Its possible wen u changed the gauge that the needles adjustments moved out of place, happend 2 mine wen i had mine out. If u can get 1 of those hand held thermo heat guns on ur heater hoses ect... 2 find out the exact temp (dont worry bout the tech 2 u dont need 1) least that way u can work out where 2 go from there.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    i was told at Holden that there's only 8 degrees between running temp and boiling so take what ya want from that and that's for a vp v6
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Subaru Liberty
    Feb 2007
    My gauge normally runs at the 1/4, but sitting in traffic can rise to 1/2, then the fan comes on. VP V6 as well. No problems with it.
    <<<< The information went data way! >>>>
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Mine runs cold and takes ages to warm up, even with a hotter thermostat. In winter this makes for some shivery rides to the servo at midnight for a drink. Come to think of it, I don't think I've ever heard the thermo come on in winter at all, except for when I'm using the A/C to demist. Brrr.
    Check out my VP right 'ere!
  1. oil temp/water temp gauge wiring
    By HUMBLZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-05-2011, 04:53 PM
  2. Temp gauge
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2009, 09:50 PM
  3. temp gauge on vc sl
    By shnap2nd in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-01-2009, 02:39 PM
  4. vl temp gauge
    By frankyj54 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2006, 11:22 PM
  5. Temp Gauge
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:26 PM
