Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: toyota superchargers
    Greedy is offline Greedy
    VN Areo
    Jun 2009
    Narangba
    Question toyota superchargers
    I have seen this topic alot and was woundering who can make up brackets and what size the drive belt should be? before the supercharger goes on is their anything else that has to be done to the engine eg. decompression gaskets?
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    The only place i know of that sell the sc14 brackets are CRS and you have to buy the whole supercharger kit off them at around $2000. When i put one on my wagon i found a pic of a tracing of the 2 lower brackets. I saved that then printed on A4. Came out the perfect size, I thought i had posted it somewhere on here but cant find it now. But good news is it is somewhere on the World Wide Web.
    For the belt if you have air con and want to keep it then go for a ecotec belt but if you dont have air con or dont want air con then just use a aircon belt and dont put it on the air con pully.
    For the motor, thicker head gaskets are aways a good idea when playing with boost but not a must, aslong as you get something good done with the tune you should be right with a standard motor.
    Now go back through all the threads you have already seen on this topic and read them, after that you shoud know all you will need to know because all the info is on here, so you might even have to use the search button.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    VN Areo
    Jun 2009
    Narangba
    Default Re: supercharger
    Thanks Matt for your help. Ill try and chase up the pic of the brackets and get biproducts australia to lazer cut one up for me.
    vn calais, vs clubsport #137
    Jun 2005
    VN Areo
    Jun 2009
    Narangba
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    don't worry about de-comp, 8.5:1 is perfect. you MUST get it tuned before driving and larger injectors to prevent engine damage. stock bottom end should do 10psi without an issue
    VN Areo
    Jun 2009
    Narangba
    10 psi without a issue didnt think they could handle that psi. Do you know the killowatts this would be puting out.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    many running 16-20 psi on stock engines
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    wouldnt htink 16psi would last to long the charger would die in a short time
    but then 16 is way over the norm
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i was meaning more the engine handling it but yeah i dont see an SC14 doing 16psi for to long.I hear a rumor that we may find out how much one will take soon
    VN Areo
    Jun 2009
    Narangba
    20 psi is that a stock n/a v6 with supercharger kit or supercharged v6 edition.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    most of the turbo boys run 16psi on stock engines my mate feads his $57 ebay engine 16psi all day every day
    VN Areo
    Jun 2009
    Narangba
    ok you posted faster then i could reply lol. Yeah i dont see a sc14 doing that but i have heard of other superchargers that toyota made that can do 16 psi
  15. #15
    VN Areo
    Jun 2009
    Narangba
  16. #16
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the SC14 will do 16psi when on a 4 cylinder but trying to do it on a 3.8 you just need to spin hell out of it yes they do spin them way faster than the limit on a lot of 4 cylinders and get really high boost too way more rpm than 10-12 psi on a v6 and they seem to handle it
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    turbo V6 = berserk
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ask matt_vp above he does 13.3 second 1/4's and he hasnt finished tuning yet
  19. #19
    VN Areo
    Jun 2009
    Narangba
  20. #20
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Man im just gettin started, i just keep getting more and more crazy ideas, Twin throttles are bolted on, just need to make some new cooler piping. I have just moved up to 16psi of boost for standard driving and god its fun. After putting the 3inch zorst on i seen the boost go to at least 19psi before i backed off and turned it down and the motor in her now came out of a car i brought a couple of years ago for $300.
    Matt
    - Lou Holtz
  21. #21
    VP Executive R-spec
    Jan 2005
    Matt will run an 11 one day (at least). The SC14 blower can make 12-13 psi staying within it's "offical" rev rating. How far past the redline can you spin the blower.... I don't think anyones tried because you need to change the main pulley to spin it that fast. But I wouldn't be suprised if you could get 15 psi from one
  22. #22
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by greenfoam View Post
    imagine the noise, wow.
    - Lou Holtz
  23. #23
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
  24. #24
    VN Areo
    Jun 2009
    Narangba
    Mace? And matt vp thats insane! a 11 sec id love to have a look some time.
  25. #25
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by Greedy View Post
    Check out my 'my ride' thread theres a few pics of the setup.
    Matt
    - Lou Holtz
  1. Reconditioned Toyota Superchargers For Holden
    By austin-flowers in forum General
    Last Post: 06-05-2009, 07:21 PM
  2. superchargers
    By Stan MR . VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-04-2007, 02:45 PM
  3. Superchargers
    By Joshua in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-03-2007, 06:11 PM
  4. superchargers
    By 8your8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2005, 02:57 PM
