Results 1 to 8 of 8
Thread: Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    xtreme_sony's Avatar
    xtreme_sony is offline MY VP IS NOW A MANUAL
    Vp Series 2, 3.8L Executive
    Sep 2008
    Default Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    I am in the process of converting my 93 VP Series II v6 into a manual. I have just started and ijust put the new pedal box in, all went in smooth. now the brake pedal is stiff. It all worked perfectly fine before. The pedal is in great condition, so thats not the prob. The brake booster itself worked perfectly fine before the pedal box swap, the brakes were fine aswell, they still work but only about 3/4 of an inch of pedal travel. Im really looking forward to finishing the conversion so i dont really want this hick-up to slow me down :-) . If anyone can please help me out, it would be greatly appreciated.
    VP's ARE THE BEST
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Have you turned the car on? The pedal will be stiff 'till you get the booster running on vacuum again.
    The 1972 HQ Kingswood
    Sep 2008
    Default Yer, Its stiff with car on and off
    Quote Originally Posted by Morton View Post
    Yer i turned the car on, still stiff. Its like its not getting vaccuum into it, but it was all working fine before. So if you have any other great idea's i would appreciate it. Thank You.
    VP's ARE THE BEST
    Morton's Avatar
    May 2006
    Is it possible you knocked out the vac hose during the conversion?
    Sep 2008
    Default Vaccuum hose is still connected
    No the vaccuum hose is still on the booster, its all connected properly. Its like the booster has locked pressure inside it, making the pedal hard all the time, engine on and off. Is there anyway of something like this happening ?.
    VP's ARE THE BEST
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    If it was me i'd check all the hoses and lines and then bleed the brakes.
    Sep 2008
    Default Yer I might just Re-Bleed them
    Quote Originally Posted by maldotcom2 View Post
    I checked all the lines and there sweet as, so i'm just gonna give the brakes a Re-Bleed and go from there. But if anyone else has any ideas dont be afraid to put them up, every bit helps. Thanks.
    VP's ARE THE BEST
    Sep 2008
    Default Its All good dont worry
    Its all good just put a Booster in from the Wreckers and shes all sweet
    VP's ARE THE BEST
  1. Brake and exhaust pedal.
    By vt dreamer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2009, 06:55 AM
  2. VB to VT Brake upgrade with pedal box.
    By Grunthos in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2008, 12:14 PM
  3. vh 5.0l brake pedal all the way to the floor
    By benny999 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2008, 08:51 PM
  4. spongy brake pedal
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-02-2006, 11:31 AM
  5. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
Tags for this Thread
