Results 1 to 5 of 5
Thread: How big is the inletmanifolds plenum bend on the vn V8 engine?
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Question How big is the inletmanifolds plenum bend on the vn V8 engine?
    As the title suggests I am wondering what is the plenum bend on the inlet manifold on a vn 5.0l engine. I am seriously thinking of dropping a nice v8 in my girl but i need to think about it a bit first and know a few things about the engine.
    Pub247's Avatar
    Pub247 is online now Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    about 67mm- 70mm at the flange then it narrows and widens as it goes around the corner
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yep about that i never measured it before i modded geoff's but i took his out to 70mm. So unless you modify your neck theres not much point to a 70mm TB.
    At the base of the neck it goes to about 60x85mm rectangle sort of shape
    VP Executive R-spec
    Jan 2005
    Mine had about a half mm lip with a 69mm throttle on it and the flange is the narrowest point. I've ported the neck out once untill the entire neck was very thin and there was no messurable gain
  1. Plenum Spacer
    By dimetime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2009, 07:29 PM
  2. Plenum???
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-04-2009, 09:27 PM
  3. strange sound under the front left during right hand bend and turns?
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2008, 09:43 AM
  4. custom plenum?
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-01-2007, 08:19 PM
  5. Everything Plenum
    By ElDubya in forum Holden Commodore How-To's
    Last Post: 28-09-2006, 06:39 PM
