CAN anyone help Plz??? I have a vn an you will be driving along an it will just stall... sometimes i'm lucky if i quickly put it in neutral she might go again.. or i get stranded, or i will go to the shops go in come out 15 mins later an she won't kick over... I'll have to sit there anywhere from 1-2 hrs... I call the racv an when they get there it starts an shows no faults.... This started all one night driving home from Melbourne to my home in the country.. So has been going on now for 1-2 mths... Finally cracked it one night got stranded an called racv he got there an it did not kick over yayy, so i thought he might be able to tell me what's wrong... He said it's not getting any spark... So towed it to garage an he said coil pack-module so had it replaced!! (mind you was done approx 10 mths ago along with the pulley).. So he replaced coil-module an 1 day later it's doing the same bloody thing.... Now he tell's me it could be the computer??
Plz someone i'm at my wits end any ideas? suggestions?
it will be the CAS, (crank angle sensor) sensor behind the harmonic balancer, have them change that.
first thing to check is the crank angle sensor. do a quick search and there's ways to diagnose it.
could also be the dfi, but that's less likely i think.
The most common problem when this happens is the crank angle sensor.
Do a code check. Read through this Checking your Computer for Faults (VN - VP), then look here Just Commodores - For All Your Holden Commodore Needs for the list of codes.
Hey thnx guys, really appreciate ur help but had my pulley done 10 mths ago, that is the crank angle sensor i'm assuming?? lol.... hey be nice i am a female here....
Can it go that quick again??
Ohh is there a way to find out it is the crank angle sensor??? Does it show up a code?? That's what i thought... Or can you try the bucket of water trick!! Cause he keeps telling me it isn't showing any faults... An i just have to keep paying him for trying new things...
is it on gas? if so have you used supergas 100% propane?
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
yeah gas is really going to affect the spark.
stop paying your mechanic to do shit. i know you're a girl, you may think i'm a guy but i may as well be a girl as well. it's easy to do some quick testing yourself, you can do it
first check codes yourself, don't trust what anyone else says. Checking your Computer for Faults (VN - VP)
then try pouring cold water over the cas. if it starts, you know your cas is the problem.
Touche....lol....
I suggest she tries our suggestions....
