Results 1 to 6 of 6
Thread: Heater controls?
    '90 S1 VN 3.8L A4 Wagon
    Feb 2009
    Default Heater controls?
    So yeh, after many hours of working and help from my dad, fking finally replaced the thermostat ( 80c instead of 90c thermostat). then replace gaskets that broke, vacuum hose for the power assisted brakes then throttle spring since that broke as well (during repairs).
    got a heater tap from a wrecker, install it correctly. now hot water flows into the car.
    however, when i replace my headunit, i screwed up the heating controls. the main control that switches between hot and cold. how do i put it back together so it works like its supposed to? also, how does this control system work? so far i understand that there's a vacuum line from the heater tap, when activated it uses engine water into a radiator within the dash but what determines how much heat is required? if i cant get the control fixed could i just have it always on heat?
    thanks for any help
    You're probably wondering where you are. I'll tell you where you might be. You might be in the room that you die in. This is your wake up call.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    there is a lever that the heater control metal arm clicks onto with a small clip that breaks usally. by adjusting that arm u can get the full range of cold and warm
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    ^ what he said. the rod goes to a thing you can see from the drives side foot well
    Feb 2009
    yeh i tried fiddling with that but i cant get a setting which allows the control to spin from max cold to max hot, it always stops way before max hot. i cant see it get the original settings.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You just need to have the control set all the way cold and then snap the rod into place with it pushed all the way back (white lever thing under the dash). I think thats how I did the last one.
    and 3 Dangerous non ABS VN's
    Feb 2009
    Quote Originally Posted by 88GreenVN View Post
    maybe i removed the white lever and didn't replace it correctly :P
    anyone want to post up a pic of the rod and lever?
  1. [VIC] WTB: vy ss heater controls
    By taztassio in forum Parts And Other Items For Sale
    Last Post: 20-05-2009, 01:02 AM
  2. VY heater , aircon controls
    By putz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2009, 11:33 AM
  3. VL heater controls same as VK?
    By Chirpstr in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-05-2008, 10:15 PM
  4. Vk Heater Controls
    By lairdy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-06-2005, 01:21 PM
  5. VN Heater and Fan Controls
    By jc_VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-05-2005, 12:27 AM
