Results 1 to 6 of 6
Thread: steering wheel problems
    VNSS Atlas Grey
    Feb 2006
    Default steering wheel problems
    hey all i've got a VN SS with the standard truck steering wheel so today i tried to remove it with a puller, which bent the puller and stripped the thread off the bolts.. so i cut the stripped thread off and tried again so now the main bolt in the centre of the puller is now stuck in there and will not turn... any idea's?? i've tried giving the puller a "tap" with a hammer while it was tight on the colum.. never had this problem.
    thanks for any help
    VN V6 0-60mph in 7.52
    Peter Brock
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    undo the bolts on the outside of the puller to relive the tension then hit the bold side to side it will come lose
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    VNSS Atlas Grey
    Feb 2006
    tried that.. it's on so bloddy tight is unreal
    Peter Brock
    Jun 2008
    golden beach
    well ya can always buy a puller for ya puller lol sorry i cant help more its sorta one of those things ya need to see to work out
    VNSS Atlas Grey
    Feb 2006
    well i drilled 2 new holes and tapped them with a 3/8" tap and used high tensile bolts.. used 2 steerign wheel puller's back to back and grinded off some so that the bolts would sit flat.. started tighting the centre bolt and all it did was strip the thread out of it. so the only was i'll be able to put a sports steering wheel on is changing the steering coloum.. not happy lol seized on that good someone may have used lock tight i odn't but it's bloody tight.
    Peter Brock
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Loctite is your friend, I use it on my steering wheel every time
    I find that tugging the wheel side to side works far better than any wheel puller
    The 1972 HQ Kingswood
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  3. VR wheel on VN. problems
    By SKNOT9 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2007, 03:45 PM
  4. SRS steering wheel
    By AndyVKSSA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2006, 10:11 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
