Hey people when i first got my VN 6 months ago the coolant in it was brown & grubby & the temperature gauge sat on around half way. I flushed the cooling system after i got it & filled with genuine Ford (im a mechanic there) coolant & water & since then the temp gauge wont move past the 2nd notch. I could be sitting on 140km/h all day & it wont even think about going up anywhere near half way. Although if it does sit long enough in the traffic it will creep up to around half way & the thermo fan will kick in but in normal driving it wont.
It bothers me a bit cause i dont want to be driving around & revving it when it could be 'cold'. Oh ive also replaced the thermostat & it made no difference & heater tap when it broke a few months ago.
How hot does your V6 run?
All perfectly normal mate, mine will creep to half way after sitting at the lights for too long, but never goes any further, and the same, sits around the second notch during normal driving. I've also recently flushed my radiator ect aswell.So wouldn't say you have anything to worry about.
hey man my vp v6 runs really cool doesnt even get enough heat for the heater to work.
its a recon 6, everything is new on it, i dunno some engines run hotter then other, or... your temp gauge may be off, which is a semi common thing
mines the same unless im in heavy traffic or idling (no air flow ) but the fan takes it to where it should be i might add my heater runs nice and hot within 5 min and im on gas to boot
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
Mine runs freakin' cold, about 30 mins in winter before the heater would be considered 'warm', that said though, if you granny drive it on a freezing cold night, it'll barely even lift off of the 'C' notch.
Check out my VP right 'ere!
yeh most of them sit around the second notch, thats just about perfect. i had an ecotec in VS which had the same temp gauge levels as u guys, rekon its pretty much the same anyway!
Ahh ok then thanks guys. Just wanted to be on the safe side incase i was slowly ruining my engine.
I changed coolant temp sensor and get a better reading ...
its located at back of engine just under throttle body ..
2 bars = operating temp and all good ..
1/2 way = sitting in traffic and or stop start driving or towing heavy load or going up a steep hill at high revs or its ummer than its at 1/2 all the time almost ...thermo fan should kick in
anything over that then you have either a leaking gasket/air in system , bad thermostat , or coolant not at 50/50 coolant to distilled water ratio, waterpump on way out, blocked radiator ...
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
mine is there abouts the second marker and the heat just doesnt seem to heat it takes 25 min to get nice sitting on the free way. is that normal
id say it seems normal im just lucky i suppose it never over heats in hot or cold always around the 2nd to third bar depending on weather its hot out or cold just gos to show there is no such thing as the normal in a vn or vp
last winter i split my radiator and drove 30ks at 120 temp gauge didn't move an inch till i stopped then it went up. love the old girl can handle anything
i must admit during winter my thermos don't run ever in winter lol they where built well with cooling in mind
i traveled 200km in my vn with a trailor and my guage didn't read above 1 bar?!?!?!? just had new radiator and thermostat fitted for other reasons and i don't wan't to through parts at it help plehs.
Mines the same stays between first and secound bar![]()
If its to loud your to old
