Results 1 to 13 of 13
Thread: Doing Manual Conversion on VP Series II v6, Wiring Question (need quick replies)
    xtreme_sony's Avatar
    xtreme_sony is offline MY VP IS NOW A MANUAL
    Vp Series 2, 3.8L Executive
    Sep 2008
    Default Doing Manual Conversion on VP Series II v6, Wiring Question (need quick replies)
    Hi everyone, hopefully some one can help me out. Im in the process of converting My Series 2 v6 VP to a manual, and i was wondering if i need any new wiring. I know that it's B**ls**t that you have to put a big massive wiring loom in cause its mostly the same as the auto. I just need to know if i need any wiring or if i can get a way with the auto wiring ?. Hopefully someone can help, CHEERS.
    VP's ARE THE BEST
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    The automatic harnes unplugs and the manual one plugs in just next to the shifter hole. It removes the neutral lock out and has a different speed sensor plug (from memory). The whole thing is quite small.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Sep 2008
    Default Cheers, BUT, am i able to somehow work around that
    Reaper
    Yer thanks mate, but am i able to work around that, as its proving hard to find the wiring for a manual, i found 1 on ebay but it just cranked the $120 mark, So if ya know of a way could you please shed some light on it. Cheers mate.
    VP's ARE THE BEST
    Morton's Avatar
    Fairstar the Funship
    May 2006
    What on earth do you need a loom for? Short the nuteral safety switch, and run two wires from the reverse relay onto the box. Done
    The 1972 HQ Kingswood
    Sep 2008
    Default Ok, Now we're Talking, Are you able to give me a full detail explanation
    Quote Originally Posted by Morton View Post
    Sweet as, i like this now were gettin some where, so could ya just tell me how to do that and plus what about my speed sensor. Whats the go with that, so yer, if ya can just clear that up it would be greatly appreciated. :-)
    VP's ARE THE BEST
    Morton's Avatar
    May 2006
    Speed sensor just plugs into the one on your manual box.
    Then flick open to your best wiring diagram, and find the +ve and -ve feed to the reverse lights (should be running into your inhibitor switch), and run those onto your reverse switch on the manual box (two metal plugs)
    Then find two more wires from the inhibitor switch (nuteral safety - consult wiring diagram), and short them permanently.
    Sep 2008
    Default Cheers Mate, Just another quick one
    When you say, "Short them permantly", is that just join them together by cutting them, soldering together ?. is that right ?.
    VP's ARE THE BEST
    Morton's Avatar
    May 2006
    Pretty much.
    Sep 2008
    Default cheers mate. Gald we cleared that up, save me $120
    Pretty much.
    Cheers Morton. Champion. You dont mind if i email you if i have any other hassels do ya ?.
    VP's ARE THE BEST
    Morton's Avatar
    May 2006
    Just post it on the forum, so if I'm asleep someone else can answer
    1) I never check my emails
    2) I'm only online once a day nowdays
    dans_vz's Avatar
    dans_vz is online now formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    Quote Originally Posted by xtreme_sony View Post
    I and many others have done a manual conversion before, I am now up to doing my 3rd manual conversion on a VP at the moment, so just ask away in here and im sure one of us will help
    Also a good read for you here:
    The complete Vn-Vr Manual Conversion Guide.
    Sep 2008
    Default Cheers Mate
    Quote Originally Posted by dans_vz View Post
    Cheers mate, greatly appreciate it, Champs
    VP's ARE THE BEST
    VP v6 in Hilux and VY SV8
    Jan 2009
    Auckland, NZ and Cairns, OZ
    HOw did you go in the end? Are you able to tell me what wires (colours) you had to connect for the neutral lockup to work please? Just got an auto loom and ecu on manual motor in my hilux and need to hook it up but only have a really simple wiring diagram from a vr to work from. Been looking for about 2 weeks to find a workshop manual but they are rarer than hens teeth here in nz. (got VP motor possibly vr loom and ecu but not too sure)
    Cheers, Tim
    VP V6 in surf winch truck in NZ. VY SV8 in OZ
  1. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  2. manual conversion (again, need quick replys)
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2009, 02:31 AM
  3. ecu question for manual conversion in vs series 2 clubsport
    By clubby_you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2009, 11:56 PM
  4. Question Regarding Manual Conversion Speedo wiring
    By Dub Alley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:39 PM
  5. Quick replies, engine coolant
    By vg_ute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2005, 03:13 PM
Tags for this Thread
