Results 1 to 10 of 10
Thread: VN executive back window winder not working
    Holden Commodore VN Executive V6
    Apr 2009
    Default VN executive back window winder not working
    Hi, as of last night my back window winder on the right hand side door isnt working. the sader thing about it is the window is winded down.
    i have put a bit of time into trying to get the window up again at least temporary but am having no joy
    so far i have managed to take off the inside door panel along with the handle of the winder. the metal piece spins but it feels like it is not making any torque with the cog inside. does anybody know how i could fix this or at least get my window up by tonight??
    please i would really appreciate ideas, thanks x
    Vt-Brrrlina is online now vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    hmmm with the inner door trim off can u manually push the window up..... if so u might have to wedge something in there to hold it up till u get a new winder mechanism..
    Apr 2009
    Quote Originally Posted by Vt-Brrrlina View Post
    hi, i have tried that but there is alot of tension from the thin wire preventing me from raising the window manually
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Drill the pop rivets out, slide regulator off window. Use block off wood or jam regulator back in there until you get a replacement.
    The wire has probably come off one of the little wheels over time and is now stuck.
    Or cheaply, WD40 - lots of it....
    Apr 2009
    Quote Originally Posted by stockies View Post
    thanks, thought about that but wasnt sure, will give it a go!
    Aug 2007
    S/E Suburbs
    Yeah it's not that hard. Regulators can be bought from the wreakers for like $15.
    It's a little fiddly getting the slide on to the window channel. But If you read the how to on power windows, it'll give you some pointers. Also just pop rivet the new regulator back in.
    Will find the size you need when its morning. Just get a 25 pact from bunnings, cost like $4
    Apr 2009
    thanks very much, willget stuck into it at work in morning, i gotta drill there =)
    Aug 2007
    S/E Suburbs
    Did you have a crack at it yet? Replacement rivets are size 6.2
    Well thats what it says on the box I have. Got them from bunnings. Otherwise, I believe that the rivets used in a VS (same size) are still stocked at Holden.
    2002 VX II Acclaim
    Aug 2008
    for like $1 each... lol
    Apr 2009
    hey mate, yeah i used a 4 mm drill bit to drill out pop rivets, at the moment i am holding up the windo temporarily with a piece of conduit til i get my arse to the wreckers hehe. thanks very much for your help! i really appreciate it!!!
  1. Window winder VT
    By Indy_387 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2011, 01:38 PM
  2. window winder!!
    By 94vrexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-06-2006, 02:54 PM
  3. How do u get the window winder off?
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2006, 05:24 PM
  4. window winder
    By bryn in forum Car Audio
    Last Post: 20-01-2006, 04:12 PM
  5. window winder
    By VH camping in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-11-2005, 04:43 PM
