Results 1 to 7 of 7
Thread: Urgent Help!!!
    markER717's Avatar
    markER717 is offline Un-Donated Member
    1990 3.8L VN Calais S1
    Jun 2009
    Geelong, Victoria
    Default Urgent Help!!!
    I am currently replacing the inlet manifold gasket as my old one s*** itself, plus putting in a thermostat as the fool I bourght it off didn't put one in when the old one broke. Anyway I ahve come across this problem, this stupid pipe wont come out and its the only thing holding down the manifold, I have taken the bolt out and it still wont budge, I have tried prying it out but im not sure whether its giving in or its bending. Any help is good help I need it in asap. Pictures below.
    Attached Thumbnails Attached Thumbnails Urgent Help!!!-21062009.jpg   Urgent Help!!!-21062009-001-.jpg
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    that's the series one and i'm pretty sure that's where the pcv is on series 2.
    can't really help you with it, but it might help if you have to describe the problem to anyone.
    Jun 2006
    I got to change my inlet manifold gasket soon .. but I rather pay someone to do ..
    that pipe joined to inlet manifold with a gasket ?
    its possible that its seized on ..
    if you got a gas bottle you could try heating it up at join and gently tap it ..
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    ghostrider, its not that hard of a job but this little pipe is a pain in the bum, I do think mabye it is seized on and I dont want to push it too much.
    pow3r slave yeah its a reco motor so it could be a s1 but the car itself is a s2.
    Jun 2006
    that looks like a nice new engine ...
    weird the inlet manifold went ....
    could it have been the bolts came loose because person who rebuilt engine did not torque them up right ?
    i think anti seize is suppose to be put on that inlet pipe so it dont get stuck .. and you have tried giving it a good spray with wd40 & getting the big flat head screwdriver and lining it up dead centre where join is and giving that a whack ... ? just be careful not to damage the face otherwise you have to use a thicker gasket to cover it.If you hit it right on centre it should seperate even a little so you can spray more wd40 or whatever to soak in.
    I was thinking of buying a gregs book and better set of tools so I can do work myself ... but I dont have the room to work on a car ..
    vp executive 92
    Oct 2008
    newcastle
    yeah mate that little pipe is a pain in the ass indeed i had to replace my inlet casket and i was hung up on it for about an hour lol flat head screw driver buddy and a **** load of patients it will come out just be brave and get a little forcefull with the bitch
    markER717's Avatar
    Jun 2009
    Geelong, Victoria
    I will give her another crack tomorrow after work, will have to get a lift in with dad. All i have managed to do so far is bend the s*** out of the part of the pipe thats sticking up.. lol
  1. need urgent help
    By sean26 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2009, 10:36 AM
  2. URGENT URGENT alternator wiring
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-09-2008, 01:10 AM
  3. help urgent..
    By matt_gotigers in forum General
    Last Post: 30-08-2008, 11:11 PM
  4. Urgent help Please
    By G4orce in forum Car Audio
    Last Post: 26-11-2006, 07:16 PM
  5. Urgent Help
    By BeastVS in forum Car Audio
    Last Post: 16-10-2006, 10:43 PM
