Yer in process of converting my VP v6 to a manual, i just took out the starter motor and found it to look the same, i have attached some pictures. I know manual starters work on Auto but not the other way, so maybe mine is a manual one. Please tell me. Thanks.![]()
VP's ARE THE BEST
Do you think that it would work on the manual ?. i spose once i put the gear box in i might just put my original starter back in and connect it and try it. If it wont work will it not fit in the first place or how do you know it is strictly an auto one when trying to put it back in ?.![]()
VP's ARE THE BEST
If it clears the bell housing it'll be fine. The reason you need a manual one is on later models than the vn, the auto starter motor has a snout which holds the end of the cog spindle. This snout does not clear the bell housing.
it will work 100% as i used my auto one and it looks exactly like the both that you have posted pics of.
George
