Results 1 to 3 of 3
Thread: air con controls stopped working
    Jun 2006
    Default air con controls stopped working
    Just tonight driving home I was changing thru the settings to blow air to my feet instead of straight to my face anyhow when I got home whilst engine was running I changed back to the whole car option and it wont change.Its stuck on blowing air to the feet...
    I have searched other threads is this caused by hose on the heater tap ?
    I did remove the coolant bottle and the washer bottle to give them a rinse a few days ago ... could I may have partially blocked hose on putting it back.... is this hose easy to replace as it goes from heater tap into the firewall...
    it seems the heater doesnt work to good anymore either ... and when I normally turn those dials you hear a pressure release sort of sound but thats disappeared.
    The heater taps is less than 5 years old and still looks new..
    any ideas ?
    Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden
    VN commodore S1 & VXII Berlina LS1
    Jan 2009
    I would be checking all the rubber vac lines for splits and such.
    That sound is the vacuum pressure thats used to change the vents, to direct the air.
    Jun 2006
    nevermind all sorted vacum line on back of throttle body popped off ...
    But one thing is the heater does go warm ... but not really hot ..... tomorrow I will stuff around with heater tap see if I can get warmer ..
LinkBacks (?)
  1. 16-07-2009, 12:34 PM
  1. Vt indicators stopped working!
    By adzee in forum Electrical Wiring / Questions
    Last Post: 14-05-2009, 08:10 PM
  2. VZ stereo just stopped working
    By 1dvsbstd in forum ASR Audio & Electronics
    Last Post: 08-03-2009, 06:35 PM
  3. My key stopped working.. :(
    By Howks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2008, 11:52 PM
  4. Tacho stopped working.....
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2008, 08:33 PM
  5. blinkers stopped working
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2006, 11:56 AM
